Re: Base fuel PSI
Truck at idle, vac line removed from FPR and plugged (thumb or bolt or whatever), set base psi to 45 for that chip. If lean at WOT and you see the integrator (and BLM over longer period of time) constantly above 128 (significantly above like 140, 150, 160.....not 129 or 130) then increase base by 2 psi until you get the results you're after. Every truck is different and I've had people run that same tune (20G, 3bar, L35s, stock otherwise) and require 52 psi base and some require 42 psi base. Just adjust for what works for your truck.
