Base run from my stock Sy
just a 6
R.I.P MyClone
Well last night i went to a local 1/8 mile track to get some base run with my stock 100K mile Sy. Not doing as good as i was hoping, here is some info from my log:
"My best run was a 8.93 @ 75.73 with a 2.015 60" I launched at 6.5psi
of boost @ 2625rpm, boost was climbing steady to 12.5psi @ 4100rpm
then it shifted to second gear, while boost continued to climb to
15psi @ 3700rpm in second gear and from there the boost was dropping
to 12.7psi @ 4175rpm and then go up to 13psi @ 4225rpm when it
shifted to third gear. In third gear @ 3525rpm i have 14psi but it
quickly drop to 11.5psi @ 3550rpm and went up to 12.8 @ 3600rpm.
Then i let off b/c the run was over."
What do you think, am i having a WG problem? If anyone wants a copy of this log send me a mail. I could use some information about this.
I also have a Q, can you get full 14-15 psi of boost in first gear with stock chip? I did 4 runs last night and the best boost i could get in first gear was 12.5 but that's just before shift. I data log 2 runs, the first run i only got 7.5psi of boost @ 3950rpm in first gear then it shifted to second and boost started to climb to 15 @ 3950 rpm and then go down to 11 @ 3575rpm in third gear.
Appriciate any help or suggestions with this.
Thanks
typhoon1588
I'm impressed at how well you kept an eye on the boost gauge and tach.
My truck runs about identical as far as PSI, but were you using the stock gauge or an AutoMeter? As you well know, the tsock gauge often lies.
As for pulling 7.5 psi in 1st on your first run, the stock computer chip has a weird limiter. On first acceleration after startup, the turbo is limited to 8psi. After it hits that mark and either the gas is let off or the truck shifts to open the wastegate, the limiter is removed and a full psi is built.
Often times while Mustang Boy is ripping the hell out of his tires in the burnout pit next to you, power brake and get rid of that 8psi limiter before you stage.
Mike
just a 6
R.I.P MyClone
It's from my data log, not me looking at gauges while i'm driving :smile:
Ok, yes the first run was after start up and staging, but should i be able to get 14-15psi in first gear? Or is the first gear not long enough to build full boost?
Thanks.
Mike
unluckyty
I just looked at some of my file, I get 12#+ of boost before it shifts out of first gear. Mine is stock but fresh, less than 3k on motor/turbo.
bdubb
I am teh kingpin!
i dont have datamaster or anything on this computer to look at the file.
i know i get 21psi in 1st gear. stock motor, stock turbo.
chadjett
i've hit my boost limiter a bunch of times in first gear. i thoght this was 30lbs for more than 2 or 3 sec. can't remember
smeagol
Umm, yes 30psi will set it off, considering stock is a 2 bar map sensor, anything more than 14.5psi or so, for 2 seconds, will set it off too.
just a 6
R.I.P MyClone
Sorry, didn't know that. On that run my spark retard was going from 0 to 4.4 @ 3725rpm in first gear. Then it was dropping slowly the whole run down to 1.6 when i let off the throttle.
But what did you get with a stock chip? More then 12-13psi in first gear?
I know i have a wiered problem, b/c at times when i floor it on the street i know i get full boost in first gear. And sometimes when i floor it on the street i get a steady boost reading and other times the boost is fluktuating between 12 to 15psi. I have a brand new bcs (boost control solenoid), i think it's a sticking WG or flapper or rod not adjusted right. I'm going to check it next weekend when i replace my timing chain and gears. But i'm still curios if anybody else have had the same problem and what you did to fix it?
Thanks.
_________________
Swede///
Sy #2550 100K
<font size=-1>[ This Message was edited by: swede on 2002-01-13 10:46 ]</font>
G
Guest
Guest
Hey Swede, I believe there is a boost limit the first time you start up your truck. After you hit full boost the first time, it will allow a 15lb boost off the line,This is every time you restart your truck, Unless you have a different chip. Bill
just a 6
R.I.P MyClone
That make sense, b/c i started and stopped the engine all the time when i was waiting to stage, and it also explaine why i get full boost when i'm driving it on the street. Thanks allot.
Daron
How about firing me a copy of the run? Id like to see it.
You can check for a sticky wastegate pretty easy, just do it when the truck is warm (gloves are a must :wink: ). I pop the rod off the arm and move the arm, a sticky one will be rather obvious.
Take care,
Daron
bullyhart@aol.com
Tooky
Serious about performance
The "first boost flag" always perplexed me because my truck doesn't seem to do it. I have stock Syclone PROM ID #3971. At the dragstrip I start it and pull up to the line and go and I reach 14 PSI in 1st gear. The "Target Boost" in DataMaster does sometimes say 6.5 or 0.0 until my boost hits that level then it will read higher, but at no point does the wastegate duty cycle change because of that, nor does my boost seem limited in any way. It's a good thing too because I don't know how to make 8 PSI to "trip the flag" while in the staging lanes, I can't hold that much boost while standing still (tires spin) and my dragstrip's staging lanes are usually packed so there is no room at all to do a little WOT blast to trip the flag.
As for the wavering boost, my truck is the same. I can send you DataMaster files if you like. Here are some example images of what my boost control looks like with the stock WG and turbo. Here is the worst:
See how it's all over the place. Next I worked on it some more and got this:
Finally after tweaking the WG rod some more and coinciding with cold weather, I was able to arrive at this:
That's only a 1 PSI difference, and I really enjoyed it. My truck made max power. The problem is that it's completely inconsistent because when the weather gets warm, my boost control is crap and it dips into 12.x PSI. In cold weather if I have the WG rod adjusted right, I can get that "nearly flat line" boost control. I have not been able to conclude if this is as good as the stock system gets (completely unreliable) or if there is more that can be done. I do know that external wastegates or PTE turbos (with good integral wastegates) are some proven methods of solid boost control.
Tooky
One other thing I would like to add, is if you are curious, judging by my past experiences I would say your truck is running right about a 14.0 quarter mile time right now.
just a 6
R.I.P MyClone
Way to slow, I want it to run around mid to high 13's before i start to modify it. That way i know i got a good ground. Can you e-mail me what and how you got your boost working ok Pix 3. I have the excact same roller coster curve on my boost at part throttle or WOT. You can really feel it in the truck when the boost is going up and down.
_________________
Swede///
Sy #2550 100K
<font size=-1>[ This Message was edited by: swede on 2002-01-30 21:10 ]</font>
Tooky
My apologies for not replying sooner.. I just loosened the WG rod all the way out until it almost feel off the thread, then did test runs and turned it in 1 turn at a time until I got the results I wanted WITHOUT going over the target boost. But the biggest factor is the weather, once it got to Fall season here, I had a much easier time controlling boost because it was cold crisp air. What temperatures are you running in when you get the roller coaster effect like me?
JoeLutz
If your running lean, it can cause low boost. I just had my injectors cleaned and now my Ty is overboosting.
