If i use Eagle ESP rods........do i have to mod the block so the has clearance to spin freely?
Syonara New member Mar 30, 2005 #1 If i use Eagle ESP rods........do i have to mod the block so the has clearance to spin freely?
berzerker wookie Mar 30, 2005 #2 Re: Basic build question nope i just did my build with the 6 cyl. part number pieces. # esp-570063d good luck with everything !
Syonara New member Mar 31, 2005 #3 Re: Basic build question Sweeeeeeeeeeeeeeeeeeettttttttttttttttttttttttttttt
bezerk New member Mar 31, 2005 #4 Re: Basic build question you got to do a little hammering on the oilpan, to clear the bolts that go with the Eagle H-beams
jwaller Evil Genius/SyTy Guru Mar 31, 2005 #5 Re: Basic build question the only time you should need to clearance the block is when you use a stock block with a stroker crank. strokers should clear on bowtie's.
