Basic tune-up, How big's the nightmare?
Josh in RI
Hey guys,
I'm gonna have to do the tune up on my truck soon (plugs, wires, cap, rotor, O2 sensor, ect,) and was wondering how big of a nightmare I'm in for. Am I gonna have to remove the upper plenum to take out/put in the new cap? What's the easiest way to get to the plugs? Should I do it myself, or should I have it done? Any insight welcome, as always. Thanks again, Josh
ABLITZ
Damn Yankee
Re: Basic tune-up, How big's the nightmare?
Josh in RI said:
Hey guys,
o2 should be fun :p
no
thru the wheel well
If you can do it yourself, I would recommend that route. A local mechanic did plugs & wires in one of the local guy trucks and threw away the factory wire looms and burnt his spark plug wire on th edown pipe.
The plugs can be done from inside the wheels, you have better access with the wheel wells off, but its take 2 hours to R&R them, alone. Plug # 3 is hard to reach, because its behind the steering shaft.
If you doing the O2 sensor, I would recommend getting cleaning the TB, IAC and replace the PCV valves, while your in their. To clean the Throttle body & IAC, you will need new TB gasket and some Carb cleaner.
If your looking for someone competent to do the job, I can do it :)
KGB Pilot125
if its your first time I would set aside like 3 hours, because you will pissed and half to walk away from you truck for a while. none if its really that hard, more or less just time consuming and once you do it a few times youll get it down no prob. also on the 02 I would spray it with PB blaster or something like that a few times and drive around and get it hot and stuff let it do all the hard work for you.
Josh in RI
Hey Dave,
If I had you do it, what would you charge me? I know it's gonna need it soon. But, I'm also like you, unemployed doing small side jobs for friends here & there. So I'm kinda on a REAL tight budget. Let me know. Thanks, Josh
Josh in RI said:
Hey Dave,
I cut you a break... I will send you a PM.
Ty0279
Historically Significant
The first time is the worst.
To make things *easier* for the plugs wires, remove the wheelwells and the two front wheels. That way you have a lot of room to move around.
Have Dave help you out. You'll learn from him.
SeattleSy#1255
Category 5 Conservative
I say leave the wheelwells in and jack up each front side of the truck...plenty of room to get your paw in there. Also, do it hours after you drive it, or you'll torch your knuckles on the DP.
Don't pay to have it done, how else are you going to learn man? Just dive in, safe money by using your time, espically if you have it...plus you learn how to make it easier next time for yourself.
Sorry, I don't get owners that want a vehicle like this, but isn't willing to put in the time to learn and at least do the basics for it. :x
Spinall4
I've been working on this one. Just bought the truck about 2 weeks ago, so far I've gotten the cap and rotor done, new coil, raised base fuel presure to 50 for the ultimate, replaced a ton of vac lines, comp. test, working on new plugs and wires as we speak. Would have been done alot sooner if I hadn't broken off a center electrode on one of my plugs. I've put in alot more than 3 hrs but I've been taking my time making sure I do it right. Its not that fustrating, but you do need to walk away and take a couple breathers. :D
SY2932
Administrator
For a first timer, three hours sounds about right. As mentioned by dgoodhue, the number three plug can be a challenge. Your best bet to get it out *easily* is to get a 5/8" swivel spark plug socket that has the swivel built in. Because there isn't enough room to get a universal joint on the back of a regular plug socket...I have one by Craftsman and it makes it pretty easy to get out. Also, a short length of 3/8 rubber hose will come in handy for starting the new plugs without cross threading them. Like SeattleSy#1255, I just jack the truck up and leave the tires on. However, it would be a good idea for you to jack it up and remove the tires and wheel wells the first time so that you can get acquainted with where everything is and you will actually be able to see what you are doing. Here's link if you forget where the wires go: http://www.whitetyphoon.com/firing_order.html
For the cap and rotor, check out this old post on some tips to do it: http://www.syty.net/phpBB2/viewtopic.php?t=37030&highlight=cap+rotor
And how to remove the rotor after you get the cap off: http://whitetyphoon.com/removing_rotor.html I smear a little dielectric grease in the new rotor so that it doesn't stick as bad the *next* time I have to take it off.
The O2 sensor can be a real PITA to get out. You will want to get a socket that is specifically made for it from Autozone, Pepboys, or the like. It is 7/8" in size and has a groove cut into the side of it for the wires to lay into. Heat it up good and use as much leverage as you can get on it... Penetrating oil may help somewhat but, it's still gonna be tough to get out. HTH's
Junior1
NASTE Member
While I'm all for doing your own work, but if this is your first time anywhere near these trucks have a fellow owner like Dave help. I had Morgan in NJ help on mine. Someone with experience to show you what to do and what not to do will save alot of time, aggravation and money in the long run. Get some help on the first one, then DIY the rest.
My 2 cents, since I'm a fairly new owner myself
SY2455
70's Veteran
If you are mechanically inclined do it yourself.
1. For the spark plugs make sure you have a swivel spark plug socket & a assortment of extensions up to 24" long.
2. Use a Conrad cap & rotor set from Auto Zone & when changing my cap & rotor I find it easy to remove the relay bracket above the dist cap to the left to give more room to work the cap out.
3. Jack the truck up with a floor jack & go thru the wheel wells to change spark plug.
4. For my truck I change to NGK #7348 or UR6IX & made a tool from heavy Brazing Rod to remove the spark plug wire boot by bending a U shape in the rod just big enough to go around the spark plug.
5. You might look at getting a MSD 6A Ignition Control #6200, your plugs will last longer & I can say after owning my truck for 2 years & doing a tune up every 4 months the best thing I did is this & getting a AFPR, bigger fuel pump, 160 Thermostat.
6. Plan on changing plug wires once a year.
I should tell you I only change to the UR6IX on my last plug change before that I was using UR5 or UR6 reg plugs, the truck seem to like the UR6IX better, they been in there about 5 months & the truck still runs strong. After you do it for a while it will take about 1 hour to change cap, rotor, wires, plugs.
bigtime
Sy-Ty Builder
I remove the intercooler, then you can get to all of the wires and the 2 PCV valves. Yes jack the truck up to get to the plugs. I would also recomend putting a new ignition module in while your back there. Get it from GM!
I just did my Sy for the first time.
Removed the intercooler
cleaned the throttlebody
Checked vac hoses
ripped out wires, plugs, cap, rotor, Module, PCV's and FPR. (now is a great time to put a AFPR in)
put on new AFPR
drained the antifreeze on both systems.
changed the thermostat
changed the belt.
I also changed my Oil sender (what a nightmare!)
Took me 5 hours.
92BlkTy
2 hours to R&R wheel wells??? :eek: were yours tack weleded on or something? takes me about 15min. no air tools. just a floor jack and ratchet.
unless you meant 2hours for plugs including wheel wells. then yea that sounds right for a beginner. it takes me about an hour total for plugs, but my 3" down pipe makes the #4 plug even more of a pain than the #3. the others are cake.
i did the plugs while swapping wheels once a while ago. it makes it REALLY easy when the wells and wheels are out of the way. FWIW
oh yea i wouldnt even attempt the plugs without jacking it up in the air and throwing some jackstands underneath it.
make sure you check your vaccum lines while your at it. if they are crusty or hard, or cracked, replace em. you can get vaccum line in spools, or there are kits avaliable. just make sure you get the black ones :D
On my Truck it takes me 15-20 minutes to get them out and an hour to get them back in. The first time I did them, it took me 2 hours. Josh's truck has over 200K miles and I know on my old 160K mile ty the wheel well bolts were slow moving because of rust (it took me twice as long just to get them out). I also snapped on of the clips below the battery tray.
92BlkTy
yea i didnt think about that. i forget my truck is still low mileage for a 92 "s-series" truck. first time i did it was at 70K and i manage to keep taking them out so the rust dosent have time to sieze them.
i guess that might as well be the same as tac welded in huh? :lol:
SY2455
70's Veteran
Hey guys how come you remove wheel well? When I change plugs I just go thru the rubber flap that cover the upper control arm.
SeattleSy#1255
I agree...just jack it up a bit, no need to remove wheelwells at all...its not easier, it only take you longer. The only way this job is even remotly difficult is if you try to do it after dring around when DP is toasty. #3 can be a pain, but once you get it down, its simple.
SY2932
Administrator
That's why you need to have one of these in your toolbox:
"Craftsman #43322 ($9.99) 5/8" swivel spark plug socket in action on plug #3."
