When yuz guys relocate your bat to the bed, where do you put it and why. I'm thinkin' right rear for weight transfer and torque. Your :2cents: please...
If I ever get around to doing it I will do mine in the right front also. Shorter cables and tucked up in the bed out of the way makes more sense to me. I don't know how much difference it would really make if you put it at the rear, it probably wouldn't be noticeable.
I'm in the process of starting this relocation. I was under the impression that the best spot would be on the passenger side, but close to the rear axle/wheel well. Perhaps some "been there done that" members can post some pics to their set up?
This is where I put mine since I didn't want to have a longer run... Though now I need to figure out how to run my cut off switch. I used 0/1 gauge wire so that I have maximum power to the starter.
All good ideas. Trouble is for NHRA the switch has to be at the rear so I was just gonna put the bat there to start with. Did anyone give much thought as to left or right side?
Might be kind of cool to put it where the spare goes, make a box and put it dead center. Come up with some kind of nifty way to make changing it less agonizing.
