Battery acts totally dead
91Syclone
I have a strange problem on start up. Sometimes when I turn the key the electrical system acts as though the battery is totally dead (no inside light, radio forgets presets, etc). Needless to say, the truck doesn't start. Once it's in this state it stays in this state
unless I loosen the positive cable on the battery and just turn it a little?! The truck usually just starts up after this (although sometimes the episode repeats itself).
I swapped in a new starter in the past but didn't do any rewiring (rush job). It's also possible a ground is bad or I missed one when the heads were off. However, I don't have weird electrical behavior except what I mentioned above.
Any ideas? How do I debug this?!
supersports10
Re: Battery acts totally dead
you answered your own question here... you loosen the battery cable and turn it???
bad connection at the battery.
the threads on the battery might be stripped.
jslezak83
Soon-to-be BoostedBlazer
i had a simplar problem on my blazer a few years back. clean both termainals. i removed the screws and wire wheeled them. wire brushed the cable end, and reassembled. all was well after that. when it was dead, if you touched the cable a bit it would make contact. try this, you should be good. -Jim
sly dvl
Ya, it's got a Turbo
Be careful if you're testing things around the battery, especially wiggling cables.
I had one blow right past my head once because the plate strap (internal) was cracked and exhibited the same symptoms you're describing. Crack = spark = boom!
It wasn't pretty. Wear safety glasses...
K
jslezak83
doesn't seem to be stock ride height...
once mine is paid off, im thinking BDS 5" lift.
sly dvl
Admitedly, the avatar is photoshopped a bit. I've got a 2" PA B/L with 32's going on in the spring.
It's a daily driver for me so I need to keep it within reason.
By your reply you have a Z? What year?
K
jslezak83
'02 X-cab. likewise on the daily driver. i gotta get my camaro back on the road. its the best in my fleet at 22+mpg
