battery drain
Flyin Ryan
hated cuz he drives fords
If I don't drive the truck for a few days or a week or so the battery will be low or low to the point where i'll have to charge it.. what could be some things to check or look for that could be causing a slight drain or draw on the battery when the trucks off? I know the ecm always has power but what else or what shouldn't have power at this point?
Thanks in advance
Ryan
WyoSyclone
Re: battery drain
Hey Ryan,
Take a multimeter and hook it up between the negative post of your battery and ground... set to read amperage. You'll probably get a reading somewhere above 25 to 30 millamps of current draw.
Pull each fuse in the fusebox, one at a time, until the current draw drops down to under 10 milliamps...this will tell you which circuit is drawing too much current. Then, figure out what component is on the circuit and why it is causing a drain.
Re: battery drain
WyoSyclone said:
Hey Ryan,
Didn't you mean between the neg cable and neg term of the bat? (Cable disconnected) Otherwise this is a good test. If nothing detected disconnect bat and see if it holds a charge. If not you have a bad cell(s). Other thoughts: Do you have an alarm? Glove box light staying on? Brake light sw failed on?
Flyin Ryan
Re: battery drain
Rob,
Sounds simple and simple is me :)
Thanks i'll do that when I get some time or a day to myself :tup:
WyoSyclone said:
Hey Ryan,
Flyin Ryan
Re: battery drain
Don,
What do you mean between the negative cable and negative battery terminal? touch both and see what I get?
Im 99% sure it's not the battery because I had the same issue with my optima red top which I took out and put a odessey in which is having the same issue.. so Im pretty sure it's a draw from something.
I have a alpine alarm but according to others who eat sleep and install them it can't be the issue... i'd just so disconnect the alarm and see but got the starter kill shit so disconnecting it to see is kinda out.. No lights or anything stays on or were left on so don't know.
sy#2921
BAMF
Re: battery drain
To get an amperage reading you need to be in series with the circuit.
Make sure your meter is setup for amp readings then disconnect the negative lead from the battery now take one lead from the meter and connect to the battery (-) terminal then the other lead from the meter to the negative battery cable and that will give you the amount of draw.
Another idea, how old is the alternator? I have noticed that all the s10's I have owned have all seem to have an alternator that would draw down the truck (Im 5 for 5 on this theory)
Re: battery drain
Measuring current between the ground post and a ground, like the engine, won't help. What you need to measure is if there is any small (milliamp is 1/1000 of an amp, 30 milliamp is 0.03 amps) residual current flow from the bat. Only way that I know of is to remove one of the cables and put the amp meter between the cable and the bat. Set the meter high and come down from there. Also setting the meter to a range that will detect low DC volts works. If you get a reading then there's something going on. Trouble is I have no idea how much is to much, volts or amps.:rotf:
Sy#2921 beat me!!!
sy#2921
BAMF
Re: battery drain
If I remember correctly my truck was about 17mA (.017A) when everything in the electrical system was in good order
jimmyz79
Re-Member
Re: battery drain
Had the same thing happen a couple of years ago. I had a consistant drain on the battery and it ended up being the stock cd/radio. There was an internal short in the stupid thing. I found it pulling the line fuse and the amp draw went down.
Bill Z
Re: battery drain
I’d like to add a suggestion here. To find the right circuit after you place the amp meter in series with the battery, with everything turned off (as you normally shut your truck down). Pull one fuse at a time until the amp drain drops to zero. Keep in mind that on rare occasions there may be 2 circuits causing the problem. This will isolate or help you to zero in on just one circuit.
Good luck.
Flyin Ryan
Re: battery drain
Well the alternator is stock and Im assuming is original.. it's an oem unit and i've owned the truck now for six years but always seemed to have this issue.. it's more of a problem now since I went with a battery the size of my blackberry so that may be the issue.. I don't want to replace the alt just yet until I get the funds and find a good replacement.
Well I removed my old sony setup (head unit, cd changer, phone setup) and installed a new pioneer unit but that didn't help in regards to the draining issue so Im hoping it's not still the head unit but you said you added a fuse inline on the power lead to the head unit and it helped? Im currently using the stock wiring
Thanks guys for all the suggestions and help.. I will try what you suggested this weekend hopefully if not sooner of course update this thread with more questions :)
sy#2921
BAMF
Re: battery drain
You dont have to replace the alternator but take it out and have it checked on a bench tester
jimmyz79
Re-Member
Re: battery drain
No, I didn't add a fuse - If you follow the wiring from the back of the radio, there is a stock in-line fuse in addition to the fuse in the fusebox. I thought it was just so the clock in the radio retains the time while the ignition is off - BUT - you said there was no drain with your unit, so the point is mute. Other than that, start pulling fuses one at a time as was suggested.
autoaddictions
Re: battery drain
FYI You can use a test light in line on the Negative terminal if you dont have a multimeter. The brighter the light the higher the draw. Make sure to unplug your hood light and remove the dome light fuse before testing or it will not work as it reads them as a draw cause there open during the test. I also wait 15min to make sure the computers go to sleep.Start removing fuses on at a time then put them back in when the light gets dimmer that the circut with the draw.Its normal to have a real dim light not bright as hell.
Re: battery drain
Bad diode in the alt is a good call, forgot that one. You can pull the bat lead and drag it across the stud in the dark and see if there are little sparks. Sparks equal bad alt. Sometimes there will be just one spark but none after, that's OK. Or pull it and have it tested, as mentioned, which is a better idea. That way you can also test for full load amps, volts, diodes, etc. Very easy to get a leaky diode.
