Battery shutoff switch?
sy2206
Has anyone sucsessfully hooked up a battery shut off switch on their Sy/Ty. I race at an NHRA track and they are pretty picky about stuff like that. I have my battery relocated to the box and got bitched at several times last year for not having one. Now I have a shutoff switch in and need to know how to wire it. Remember, it has to kill the truck, so just disconnecting the power will not kill it because the alternator will still supply the EFI and ECM and so on and it will stay running, I tried it! I need to kill the alternator and battery power at the same time. I could take all the wires from the power output terminal on the alt and run one wire from the back of the alt to the upstream side of my switch, the run another wire from the downside of the switch to all the wires that were on the supply term of the alt? Or, I could shutoff power from that terminal with a relay, which would be tripped by the main shutoff switch. What do you think?
Mark Christofferson
91 Sy #2206
12.47 @ 105.6
use 2 parallel heavy duty relays to break alternator or the switch from flaming river that has alternator continuity lugs built in and switched simultaneously.
call me at work if u need the part # or wanna buy one
mike
bdubb
I am teh kingpin!
wanna just "Kill the truck"
wire it into the ecm -b fuse. so it cuts the power to the ecm, instant shut off the truck. thats how bG did it back in the day.
Hint,
If ya go the relay route on the alt wire be sure to get a continuous duty relay, not a starter relay. Starter relays can handle the juice but are not designed to be "on" all the time. They may look the same if from the same manufacturer so be careful.
Don.
bdubb
I am teh kingpin!
rockvillespeed said:
i dont think thats nhra legal
i doubt so too, but then again, who cares? if it passes tech, it passes tech. most of the local hilljacks just want to see it kill the truck, never seen one check voltage anywhere, or such.
smeagol
Nope, but their idea of having to cut the hot side of the battery is a stupid one anyways. We discussed it at length some years ago.
I did the cutoff killing the alternator feed, used a weak relay the first time, it sucked. I think Painless sells a setup for that. Gotta make sure you either have a hd relay or the dual post simultaneous switch.
I think someone posted a good site for all sorts of battery cut off/ connectors/switches etc... anyone recall it? I think Lynn or someone posted the URL.
