EcSy#2671
Si vis pacem, para bellum
Well she dead, time to start over. Main bearings are toast. First rebuilt for me. What parts you recommend? For street mostly, and some race use. I would like it to be strong and reliable, a little fast would be nice too. I was thinking these from RPM to start. I was going to use the stock block and convert to 4 bolt mains.
RPM Cam Bearings
Clevitte Main Bearings (.010)
Federal Mogul Rod Bearings - (.010)
RPM Stock Crank - Nitrided
Victor Reinz Engine Rebuild Gasket Set
Victor Reinz Head Gasket Set (SyTy, everything from block up)
Eagle Connecting Rods - 5.7" H-Beam (SyTy)
SRP Pistons - 4.030 (8.5:1)
What pistons rings do you recommend for SRP pistons? I'm I on the right track?
I could use all the help I can get. Thanks
Erik
RPM Cam Bearings
Erik
