bel-tech leafs&set back plate????
syclone1100
RUNNIN AND SELLIN
Just got my bel-tech lowering leafs today with no hardware so Im guessing I use the exsiting hardware already on the truck.. and I wanted to know since I couldnt find anything on it in a search was can I use the JTR set back plate with the new leafs or is it just for the lowering blocks????
ashman
Re: bel-tech leafs&set back plate????
I didn't need setback plates with my beltechs. think they're just for blocks.
WannabaTY
I didnt use leafs. I did my own blocks with the holes offset.. Worked perfect
bizkit
bonofied SyTy junkie
Yes you can use the set back plates. I have them on my Ty with lowering springs and the wheels are nicely centered.
syclone1100
RUNNIN AND SELLIN
does it affect the drivetrain at all?
SEL777
One of 101
X2
bizkit
HTML:
The set back plates move the axle only an inch or less and the driveshaft has more than that to play with, so no it doesn't affect the drivetrain. It would actually improve the pinion angle, though it would be a very insignificant change ( longer drive shaft = less angle)
Don't worry about it just do it, plus the 3/8" it lowers the back of the truck is bonus.
SYTY66
I just received the BEL-5954 3" lowering springs. Just ordered the set back plates from JTR. But I have another question, Do I need to install the stock angled wedge? Pls advise
yes on the wedges. do away with the small flat plate on the bell techs and re-use the wedge.
Loeryder
and that 3" quoted drop is for a stock S-Series.
You'll see more like 1.5" - 2" drop on a Ty.
I still used 1" pinion correct blocks with my Bell Tech springs.
SY1616
Just the Belltechs here and everything is nicely centered!
allwheeldriven
+1
That it is how mine was done and everything centered back up like it was.
But,
I have noticed some Syclones even stock seem to have one wheel centered in the wheel well more on one side than the other.
No Idea what's up with that.
