wut would be recommended for making my ty faster.. its all stock... boost controller? chip/tune? walboro pump? air intake? any ideas or a good setup that works... not lookin to go insane but to have some fun... thanx:tup:
Before any other mods do a Walbro 255 (from a Reputable retailer like SyTyperformance.com or Racetronix), an adjustable fuel pressure regulator, and silicone vacuum lines from Sportmachines.
You've started here, right?
http://powertuneplus.com/syclone/howto_stock13s.shtm
Get all that done before you go any further.
-P
Cool ill check them out n go from there.... how much u looking for that chip boost controller n.injectors???
Bad idea. Get your truck running right first, then mod it. Even then, not all mods work on these trucks. Example: In one case, removing the stock intercooler setup and going A2A did nothing, despite spending almost $2000.
I'd hate to see you end up with a thread titled "WTS: Blew my shit up making boost."
-P
Did you go into it thinking it would make a difference, just curious?
When I did mine I purely wanted to stop having to deal with how heat soaked the I/C gets. That and it's sooo much easier to deal with when having to work on the engine.
good start!You've started here, right?
-P
195* to 160* thermostat = .2 in the quarter with a Sy.
Make sure the truck runs good with scan tool as mentioned in powertune plus website. Do a full tune up make the IC pump works add a walbro and fuel pressure regulators. (you can do these mods along with getting to run good stock). A stock typhoon should run high 13's.
If you want to do DIY tuning get a wbo2 and code59. Otherwise get a like the ultimate or the new chip from turbo tweak. The chip will control the boost for you. If you want a boost controller, get an external wastegate installed. you can get a typhoon to run low 13 to high 12 with these mods.
I think it means wideband O2
255 fuel pump w/ adjustable regulator, IC pump hotwire and reroute lines, voltage mod, scan tool, 3 bar map and compatible chip 18-20 psi.
IMO their is no need to Hotwire the IC pump relay (ie cut the factory wiring) if you doing an aftermarket chip. The aftermarket chip will turn on the IC pump all the time anyways.
