Best "bolt-on" turbo?
ranger
Hi folks,
I currently run a stock turbo that's been modified with bigger wheels on both ends, as well as one-size larger exhaust housing (12 cm2?or is 10 cm2 the one that's slightly bigger?)
When the turbo was rebuilt, I should have had a brass or bronze bushing installed in the wastegate shaft, as it always sticks and I end up overboosting. Spraying with Mobil 1 penetrating oil helps, but only for a short time.
In addition, I suffer from the wastegate hole that is too small, and I have to run a converter or it overboosts, as well. The guy who rebuilt the turbo used to work for Texas Turbo, then branched out on his own a few years ago. I can't remember his name, nor the name of his company.
I have been off the the Sy/Ty lists for a while, but have owned my Sy #1563 for about 10 years.
Any suggestions about what I should do? Have my turbo rebuilt with a brass/bronze sleeve, but that still doesn't fix the prob. of the small wastegate. The guy who rebuilt the turbo said that it's pretty hard to get in there and port the wastegate hole.
Thanks for any info.
Cheers,
Craig Stangohr
Aiken, SC.
12.71@106.42 @18 lbs.
Re: Best "bolt-on" turbo?
From what I hear a 3" downpipe with the wastegate access port open, helps boost control. You will need to open the port on the exhuast housing which sound like you need to do that anyways.
Who built your turbo? Is it a 20g wheel? It probably is 10cm2 housing (stock is 8cm2)
jwaller
Evil Genius/SyTy Guru
you dont need to rebuid the whole turbo just bush the wg arm hole and port the flapper and you will be perfectly fine.
It's just a six
Super Member
So, when is a larger flapper necessary to control overboost or boost spikes?
A larger valve is not at all necessary?
Thanks
12.29 @ 108
Stock turbo can be made with good boost control. As John said port it. One step further is to remove the plug in back and modify or make new downpipe to fit. That helps more than you think as it eliminates 2 90 degree turns the wastegate flow must take.
I had a group purchase of downpipes with a Flange from JS that does this exact same thing. I had good succes with my DP and I had great boost control. I would go for that if I could.
TYTILIDIE
METH HEAD
What plug are we talking about? I am interested in doing this. How much is htis DP?
If you look on the exhaust housing of your turbo you will see a "puck" with three welds on it to hold it in place. If you take this out, it will allow the wastegate to flow directly into the downpipe instead of going up into the general exhaust exit on the turbo.
You can get a flange from JS. Any exhaust shop should be able to do something for you. JS might even do it if you ask nicely and he doesn't ahve anything better to do...
ranger
Hi folks,
I kindly thank your for all your replies.
Yes, I have the 10cm2 housing with the 20G wheel. I lived in Chicago for my whole life before moving to S.C. Used to run into the Chi-town boys: Opie, Brian Green, Ivan the Terrible, and others--not that I used to "hang" with them, by any means. Ivan turned out to be a bit of a crook, as he sold a bunch of folks some leaking fuel rails and failed to "make good on them," last I heard.
The guy who built the turbo was the guy who used to work for Texas Turbo, then started his own company. Can't remember the name, but I bet he's still in business. He had told me that he really couldn't port the wastegate all that much, as it was hard to get to.
I also run a 15 p.s.i. actuator, in an effort to control the boost a little better. The downside is, my Ultimate chip can no longer be used for boost control. I have to run a bleeder valve.
I will call JS manufacturing, as I would like to remove the plug in back and get a new downpipe made to fit.
Where would be a good place to send out the turbo to get it sleeved and ported? I don't think it should need a complete rebuild, as that was done 5k miles ago?
Thanks for all your help.
Cheers,
Craig Stangohr
Aiken, SC.
Sy 1563
12.71@106.42
You shouldn't have to send the whole turbo out for repair. The exhuast housing is held on by a clamp and should slipped off with just 5K miles. (the exhuast housing is a big piece of metal with passages and a flapper)
ranger
Dave,
thanks for that info. That is a lot easier than removing the whole turbo with all the oil and water lines, etc.
Cheers,
Craig Stangohr
Aiken, SC
Sy 1563
12.71@106.42
ranger
Hi folks,
well, after taking my foot out of my mouth, I realized after my last post that I will have to remove the turbo from the truck, at any rate, to remove the exhaust housing. Duh!
Regards,
Craig Stangohr
Aiken, SC
Sy 1563
