best hose to use?
I replaced the hoses on the Syclone, and figured I might as well replace both the hoses going to the catch can. I picked up some nice hose that was flexible from O Reilleys, but here is the problem- it is forming a small amount of coolant where the hose goes on the nipple of the intercooler tank. The hose is pushed up as far as it will go. The hose I bought was specifically for overflow tanks, but it doesn't seem to be working all that great. The inside diameter of the hose I bought is the same as the factory pieces, but the outer rubber is a little thicker than the original. I know I should have just left well enough alone, but I just couldn't.:lol: Anybody ever replaced these with something that worked good? Oh, BTW I threw the old stuff away thinking the new hose would be much better.:rant: As always thanks in advance guys!
Re: best hose to use?
You mean a leak? You can buy mini screw type clamps or I've also seen mini spring type clamps of various sizes in a little packet.
HTH
It is not too bad, there is just enough to get your finger damp after it's been ran. Come to think of it I'm not sure if it seeped any until I put the new Johnson pump in a couple weeks ago. I know the clamps you are talking about and that may not be a bad idea Don if I can find some the right size.
Dave, I believe you are correct! The cap was pressing down on the hose and creating a leak. I looked at several auto parts stores, but couldn't find anything better than what I had. I wound up taking the hose off the nipple and turning it 180*. The thickness on the hose varied enough that by turnig it, the cap cleared it better and thus seemed to have stopped the seepage. Thanks again Dave and Don, both your ideas were greatly appriciated.:tup:
