best torque converter for stock setup?
atomicmecha
I hate rust
Whats a good torque convert to use with a stock motor and transmission. Will be running an ultimate chip with 3bar map. And already have an aux trans cooler installed.
Slyclone
Well-known member
Re: best torque converter for stock setup?
I had a converter installed in my typhoon which was stamped with "7" all around the outside.
If you can source one of them, probably your best bet. Might run $95-$100.
When I pulled my syclone apart the stock converter was a GM unit and had the 7 stamped all around outside.
Medium stall. 2100 or something in that range.
Priceless
I use the B&M 2400 stall. Pretty nice so far for what it is. Im a little bigger than stock but builds boost nicely.
IGottaSy
Mines around 2200. 2400 sounds about right according to the stock engine's powerband.
With the stock diameter do not go above 2,400 rpm. Use a quality torque converter, not TCI or B&M. Too many torque converters from these two companies fail and when they do they take out the transmission.
