Better lowering alternative idea
Horsehammerr
Re: Better lowering alternative idea
There are 3 holes.. Look at the rest of the pics on that link in my last post. I assume that top bolt hole is threaded and you just run a bolt in from the other side...
EDIT: Grabbed a pic for you:
Somehow I missed this entry before posting my last ?? The only thing I question is the spacing between balljoint mounts. Do they match stock spindle measurements ? Is the only change , the offset of the Hub bearing location. If the balljoint spacing is wrong , the steering will be screwed up.
Black Knight
I Glow Therefore I am
The pictures look like they move the axle very close to the upper ball joint. If you've ever put drop spindles on a 4WD/AWD (and I have), be aware that a lot of the times you have to cut the threaded part and most times the nut down to be able to clear the axle. It's pretty sketchy, but I did one about 9 years ago on a full size Chevy and it's still holding to this day.
