better than a typhoon
tnsyty
http://nashville.craigslist.org/cto/3182199209.html
Craigslist said:
Awesome! GMC Jimmy Blazer-Better Than A Typhoon...Fast w/ Working A/C - $10900
Craigslist said:
1994 GMC Jimmy 2 Door Blazer
'94 300+HP Corvette LT1 Engine
*Lingenfelter 52MM Throttle body
*Custom Low Restriction air intake system
*Full 2 1/2" Low Restriction Dual Exhaust System
700R4 Transmission and Transfer Case
*Complete Rebuild with Corvette Cutch Packs and 5 Gear Planetary
*Selection of 2 or 4WD Electron
Computer- 1995 GM ECM
*Custom wiring harness with sequential fuel injection *Full emission functions
*Fan control *Programmable transmission control
*Custom programmed computer *Full integration into factory wiring on body
Body Modifications
*Corvette shifter assembly *Corvette 17" Wheels *255-50 Goodrich G-Force Z rated tires
* Typhoon transmission support *Body lowered Two inches *Revised steering mast to eliminate shifter
*Typhoon torsion bar support *Custom fiberconsole *Custom instrument layout*Carbon fiber instrument fascias
*Door handles and tailgate ornaments removed and filled
*Nordskog Digital instrumentation with available readings for: 0-60 MPH Time, 1/4 Mile Times, Highest RPM readings, Highest Speed
Options
*Air conditioning *Power brakes *Power steering
*Power windows *Power tailgate *Cruise control
*Rear wiper/ rear defroster *Tilt wheel *Intermitten wipers
*Remote release doors and tailgate *Custom cupholder *In-dash AM/FM casstte and CD player
This was a professional build.
It is still 4x4 (four wheel drive) and it works.
It has been lowered.
Looks great, runs great.
Would cost well over $20,000 to build.
Logan
Re: better than a typhoon
Pretty slick toy but I don't see it fetching 10900. I agree with a previous poster at 6k. I don't know about "better than a Typhoon" though.
Throws
Never buy someone else's project. This thing has crack pipe written all over it.
-P
blue83z
Lt1's suck. Sold my Impala SS cause it needed an opti, was looking for something else for a DD, so i bought a 95Z28. A month later, opti went bad. My dad has a 97Z, they are both at my friends shop for optispark surgery. The cars are cheap though and fine for a DD.
Replacing an opti isn't that bad enough to sell a car. Hopefully you had some other reason to get rid of it. I have seen 140k mile cars running strong on the stock opti. I had one go out at 60k miles, but those were pretty hard miles.
Sure it was a bad idea to put an optical sensor under the water pump and make the rotor out of some flimsy plastic, but at least they got 360 degrees of timing fidelity out of the darn thing. Better than the SyTy distributor that is +/- 2 degrees. It is too bad that that the Opti isn't easier and cheaper to replace, otherwise it might have caught on.
My experience thus far is that the SyTy's are more of a pain to work on than F-bodies. Now the execution on this particular truck would give indications of how much work it would be. To me it looks to be pretty well done. The corvette accessory mounts are used for the alternator and the AC which eliminates the need to notch the frame. The AIR pump hooked to the throttle body is a little weird, I guess he had to meet emissions in Nashville?
I guess it depends on how you look at an optispark. You can think of it as an ignition component that wears out or eletrical sensor that goes bad. Inthink of it as wear item or the bigger flaw is the optispark is unforgiving for getting wet by either the water pump leaking or washing the engine.
