Better than plastic spark plug wire retainers
IGottaSy
Bail wire.
Just kidding! :rotf:
BUT I do use an old spark plug wire boot when changing my plugs.
It fits nice and snug and sticks out just enough to comfortably allow two finger operation:oops:
Jimmy
Banned
Re: Better than plastic spark plug wire retainers
bail wire.
But i do use an old spark plug wire boot when changing my plugs.
ok
Icarus-54
Donating Old Member
I use a piece of 3/8 fuel line about 6" long
blue83z
best thing I ever did was buy a snap on spark plug socket. worth every penny over a craftsman or whatever. The rubber holds on to the plug just perfect for some of the PITA ones.
Only issue I ever had was that it would hang on so tightly to the spark plug that the extension would pull out, leaving the socket attached the the freshly installed plug. Sucked when doing most OHC engines. What was the issue(s) with yours?
gkrcr882
SyTyless......for now!
I have a Mac one with the magnetic insert. Holds the plug tight enough so it wont fall out, but not so tight that you can't get the socket off.
blue83z
I never had it hang on too tight where it would stick on the plug and the extension would pull out. Ive had it for probably 15 years?
