Jer
Don't taze me bro!
After weeks of trying to track down the cause of my inability to produce over five pounds of boost under WOT, I finally was able to pressurize my intake and confirm that it was indeed the end tanks of the intercooler. The end tanks are plastic and there's little aluminum 'fingers' that hold them to the core. This seems to work fine for ~15psi but when I added my methanol injection kit (Thanks Razor) and began cranking up the boost, it wasn't long at ~25psi before the 'fingers' let loose and the end tank was barely hanging on. As you can imagine, this doesn't offer a very air-tight seal for an intake system. So, if your plans are on the boring
rotf: ) side of 20psi you might be alright. If you have long term plans/goals to run mid to upper 20's (or anything above 20 for that matter as I'm not sure just how much would be reliable on these) in the way of boost, I would suggest a different route.
I've ordered a Spearco-esque FMIC that's comparable in size to the Saab w/2.5" inlets and outlets and the height is four inches shorter (11") and the thickness is almost double (3" vs. ~1.5") and the overall length from inlet to outlet is about the same and the core is slightly wider (Saab 22" vs. 24") and the inlets/outlets are straight out whereas the Saab intake/outlet is angled down and the overall thickness of the end tanks on the Saab at the largest point is much larger. I'll take some pics when the new intercooler shows up for comparison and what not. The new intercooler was less than $250 with shipping and two blue silicone couplers and four stainless T-clamps so it really wasn't that bad. It's rated at 600-700hp and pressure tested to 35+psi (just in case I get really nutty
) and is efficient to 0.5 psi @ 15psi and 2psi @ 35psi. So, for not much more money you can get something that's probably much more efficient (Not sure what the rating is on the Saab IC is since there are relatively no specs available on it) and will flow for at least twice the hp levels (based on over all size difference as the double thickness adds for quite a bit of capacity) than what the Saab offers. Plus, you know that it's not a weak link of your intake system just waiting for the right time to let loose.
