BIG GUNS: What did you keep?
Throws
So... as I'm working through a distributor issue (MSD-TSP Copy is wonky), after deciding on going back to a stock distributor, I got to thinking: What's better left stock?
I mean, you guys are running some fantastic times... so (without giving away secrets) what did you keep in stock form? We've all heard things like "stock downpipes are good into the 11's", or how the stock intercooler is a fine piece up to a certain point.
So... what did you find better leaving alone, as the stock part was more reliable/cheaper/easier? What did you ditch first?
-P
Aeroking
e.i.
Re: BIG GUNS: What did you keep?
not a big gun, but a pistol. Mine gets better the more OEM parts i take off.
Matt
no big gun either but my best is 11.6 stock distributor, stock downpipe, stock upper and lower intercooler :tup:
Syclone#2960
What ever it takes!!
I'm running the stock distributor...with the NGK plugs gapped tight. (.20-.25)
Syclone#2960
Ignition box? Coil?
What's the first thing you shitcanned?
-P
MSD 6l-2step box and the msd stock type coil.
Honestly I would 1st install a meth kit from Alkycontrol over any other performance mod.
The 1st thing I shit canned was the stock turbo.
killa66cam
RIDIN DIRTY
What is your 11.6 setup Matt?
I guess I need to get off my lazy ass, and get my damn Alkycontrol kit put on!
Cam
qbnkiller
Conflaguration Specialist
Stock exhaust manifolds got me to almost 130mph at.3900#. I also was still rocking an Autozone reman distributor. The stock crank.lived in mine to well over 800.
I have considered building another true TOP STOCK engine using what I have learned, but I have moved on to bigger things!
Throws
First thing you shitcanned?
-P
Throws
Cam
Yeah.... It was one of the things that I feel made a huge improvement (for what I've done so far).
-P
qbnkiller
I would do a stand alone ecm and turbo/fuel system/turbo/exhaust
Maxtor
To run 11's, the key things I did was stock ECM tuning, slightly bigger injectors, slightly bigger turbo, and meth injection. Today I am still running the stock intakes (kind of, although modified), stock distributor, stock coil with a digital 6 box. Not much else is left from the land of stock.
pearl91chevy
I still can't even get in 12s with bigger turbo, injectors, Tt chip and misc stuff lol
SYCLONE#1531
'MOFOFAST
11.40 with stock style billet distributor with msd to keep spark from blowing out! Stock cammed engine. 7.2 1/8th
autoaddictions
Engine block with 4 bolt main conversion. Upper and lower intake lower was ported! Crank all though cryo treated. Stock manifolds all though extrude honed. the front axles and rear end where still stock. Everything else was aftermarket.
Best mods i made.
4L80E
Meth
Ditching the factory ECU Big Stuff 3
RPM turbo kit 72mm precision turbo.
AMS1000 boost controller
Ported Vortec head package
killa66cam
RIDIN DIRTY
all that shit you been buyin cam and you dont have alky?
Yea Ron, I got it already. I just need to figure out what the F I am doing, and stop changing my mind all the time. Then I can stop buying stuff for each option, and focus on one!
Cam
