Bigger injectors vs. 7th injector system
BPATT
I am wanting a better fueling system which would be best bigger injectors or the 7th injector system... Plus I think I am going to use the superpump that atr offers.
thanks BP
ParTyBoy
I'm not the guy to ask on this.. that would be Brian Green, but from what I can recall the 7th injector system made by ATR is useless... Upgrade your injectors to 50#'s hopefully that should cover your range unless you're past 500hp and get Brian's 50# chip when he's finished...
BTW: Green are you finished??
How's it coming along??
_________________
"You're your own juice factory."—Testimonial
<font size=-1>[ This Message was edited by: cHoCco on 2002-01-14 10:50 ]</font>
smeagol
BP - what mods do you have?
50s - still looking for beta testers with stock motor and the right upgrades, as well as owner with tuning skills.
ParTyBoy
On 2002-01-14 11:03, BPATT wrote:
Where do I get the 50# injectors all I see is the 40lbs in the atr book.
BP
I've got a hunch that you're new at SyTy's.. this is going to take some time.. We've all been there at one point or another, but there's a larger playing field than just the people that create catalogs claiming they have what you need.. Superpump?? haha. Best advice on the pump.. purchase a walboro.. Come in 255#(reg. or high pressure), 300#, 340#.. 255 is fine for most and will only set you back $100 or so.. grab it from ron gregory on the list... A good source for 50lb injectors is Precision Turbo & Engine (www.precisionte.com) Question for you. why do you need larger injectors??
Let us know how we can help
_________________
<font size=-1>[ This Message was edited by: cHoCco on 2002-01-14 11:56 ]</font>
BPATT
You are correct I am new at this. I am new at the SYTY. I have had the truck (TY) for two years. I have done some bolt on part but I want to do more now that the truck is paid off. I have some money to spend on upgrades here and there. I could be wrong but this is what I am thinking. The motor is stock. But I have a upgrade turbo on it, but I want to change it out to a 20g, I am getting headers, 3" down pipe, I already have the cat back. I am going to use the ultimate chip, I have the FPR, trans cooler, trans has been rebuilt with 2400 stall, I am changing the conv to the 9/11, I have the air filter relocator, plus the aux cooler. I just thought I would need to upgrade the fuel system also that is why I was checking into the superpump and the 50# injectors. If I am wrong in my thinking.. Please help..
BP
smeagol
What upgrade turbo do you have on there?
A 20g won't require upgraded injectors, but an upgraded Garrett based one will. A 3" downpipe isn't available for the Mitsu 20g. What are your goals?
Don't buy anything without consulting the board, now that you are here :wink:
BPATT
I don't know what size it is. It is supposed to be one step up from stock. Is there some where on the turbo where I can see what size it is? I am not trying to break any records I just want it to be strong and reliable. Thanks for the info on the 20g and the downpipe. I will keep consulting the board you can save me some pain.......
jwaller
Evil Genius/SyTy Guru
you must find out what turbo you have. this is so very important. the need for bigger injectors many not be the best way to spend yourt money...what tool are you using for tuning..datamaster diacom a scantool or what...this is usually the VERY first thing you will need. this way you can check up on the progress and usefullness of your modifications
BPATT
I am going to use the datamaster as a scan tool. I had a fellow SYTY owner to do my previous work but I am going to try to the rest myself.(WISH ME LUCK) I am putting together a game plan and buying the parts now. I am in Ohio and it is two cold to be working on a car for now. But I will be at it in a couple months.
