TyphoonB said:you can also pull all the injectors out and check for flow with pressurized air and a bucket of water, this also requires pulling the fuel rail out too in case your confused.
JustDreamin said:What color is the smoke on startup? White / blueish smoke on startup would be oil smoke (from valve seals or maybe piston rings). Black smoke is a pig rich condition.
'Dreamin'
NecroWolf said:must be the drugs. hadn't thought of that one. i'm pretty sure i'm losing fuel pressure, if the truck sits long it takes a bit to crank up and puffs quite a bit of smoke on start up everytime, and it's too much to be valve seals, unless i don't have any valve seals
