blew the head gasket today
qbnkiller
Conflaguration Specialist
Re: blew the head gasket today
sorry to hear that bro....I hope you can get her up quick!
1madgumby
thats what I can't figger out, runs strong, only 10-12 psi. 50% throttle, never has been 100% throttle. Just have to change it.. that is what it breaks down to. sucks. might even be the intke gasket. not 100% sure. anyone want to do some wrenching??
Sy-1177
Turbo Inside
I told you not to paint those head gaskets teal... see what happened! ;)
Trapper
I would come up and help but I'm a little far.:roll:
bezerk
before you do anything.
take the lower intake off and block those ports on the heads. and pressure test it than. it's not that big of a deal. it wouls suck to tear the heads off to find out those gaskets are still good.
1madgumby
brown wire unhooked was realy close to 0-3.. with these gaskets. pulled the plugs & the #2 &#4 were wet so I pulled the intake, just going to change the passanger side gasket. Drivers side is A bitch to get off with studs. will do A comprsion test tommrow or the next day. Sucks, had my mom out helping me get the intake off, she needed somthing to do.
http://www.sytyperformance.com/inde...facturer_id=0&option=com_virtuemart&Itemid=26
Windedv6
Ty n 10s
brown wire unhooked was realy close to 0-3.. with these gaskets. pulled the plugs & the #2  were wet so I pulled the intake, just going to change the passanger side gasket. Drivers side is A bitch to get off with studs. will do A comprsion test tommrow or the next day. Sucks, had my mom out helping me get the intake off, she needed somthing to do.
The plugs were wet with what? Fuel? Oil? Water/antifreeze? What Torq spec did you use on the studs??
John
1madgumby
water/antifreeze, was smoking for just like 1 min, was not to bad. Can't recall torque at this time. I belive it was 85 flbs. not 100% on that.
