blew up my motor...
alaskan
like it says i blew up my motor today, actually i scattered my motor today... not as cool as it sounds. so i need to replace it. so i need some ideas waht is the best band for the buck as far as puting a motor together. not opposed to doing whole motor, or building a new one. but would need new block as the window in the side of mine makes it a little hard to rebuild. so i need ideas on a good budget build, the key is budget.
supersports10
Re: blew up my motor...
cheapest way out there is to use a 96 and newer shortblock reuse the heads cheap cheap cheap can be done for as little as 500-800 dollars
Ross L
inquiring minds(or maybe just nosey people) want to know how??? What happened?
alaskan
will the oil pan from my motor work on a 96 block? also what years were the l35 engines?? i want to pump it up a little before it goes back in, i am just looking for the bang for the buck modifications.
alaskan
i know how, i am a mechanic by trade, i was looking for maybe the inside info on the cheap hot rod modifications. not exactly sure what happened yet, it was dark when she blew, so i just had it towed to the house and started drinking... goona look here in a minute. i know everbody says it but, i wasn't even beaten on it when she blew. turned the corner to the grocery store and the whole car jumped and that was all she wrote. crapped out all the oil all over the road. so i got a tow and then got the hell out!
jpalmer
with the newer block,you will need a 4x pan from the vortex motors, i have one laying around ill sell ya cheap,or buy a motor out of a 4x truck with the pan, little modding to the pan for the turbo oil return line.
With the vortex heads you will get a little more power and you can add a little more timing because of the combustion chamber, cheap and fairly easy. Search in the projects threads and you will find a few times this has been done. good luck
BoostedSUV
only problem with building a motor anything but stock is tuning issues... Change the cam, switch to vortecs (not vortex),ect will require a retune on the ECU. Trust me it can become a headache. You can do a real mild build (good bottom end, crane compucam etc) and not need to worry about retuning the truck. Just a friendly heads up... when you start making major mods you're in for a tuning headache. Been there, done that!
alaskan
not afraid of the tuning, tuned a few cars. just not really sure what is availible for these cars
tnsyty
Same thing happened to mine. Previous owner, ran it on race gas and high boost w/ supporting mods several times. Then one day he was just driving it to work and at no boost and it made a window into the block. He said he wished he had a good race story to tell about it.
MYYellowTY
WOW, whats in the oil these days.Mine just spit a piston and rod out the pan.I was only going 35 , not beating on it either.Weird how alot are poppin all of a sun.Mine was runnig the best it ever has too. Would a 96 Vortec only need 4x4 pan and intake converted?Would it need a retune then if its all stock other then motor?Thanks!!!
sy#2921
BAMF
I'm willing to sell my motor seperate from the turbo/headers if you are interested in a built motor. Check for sale section for all details. PM me and we can work out a deal if you need just the long block or what.
syclone3
You guys that had engines expire? How many miles were on them? Curious. A buddy had an all original Syclone, 7000 miles and it spit the lower end all the over the place. Seen them with over 100,000 miles and still running strong. Go figure.
NJ93TY
Mine has been making a knocking noise for about 2 weeks. Well I noticed the oil pressure was wacky and the lower end knock was getting louder. As I was driving it I realized, I'm screwed, drove it home, parked and covered it. Its gonna blow up but I figure park it now before it does.
