blk00z28
Forced to by choice
I know the biggest pro and con of doing this. Makes the block stronger, but makes it run hotter. What are everyones opinion of block filler?
I'm gonna be spinning the motor to about 6500. Also running 4-bolt mains. Going to run studs rather then bolts just about every where I can to help hold it together as well.(including the heads.)
The psi I'll be running? :dunno: I guess I can say 25psi. Maybe a little more.. Depending on how it runs, or more of what it runs with my setup.
The blocks not going to the machine shop until I get the heads done(before Feb.). So any and all ideas will be helpful.
One off topic question, what extra holes have to be drilled into vortecs for bracks?
