Block going off to machine shop: checklist?
PPI Typhoon
DIY Madman
Ok, pardon my ignorance here. I've spent the past couple hours browsing thanks to the search option.
I'm going to send off my extra block (out of MadPSI's truck) to the machine shop. Going for a 4-bolt conversion. Looking for a checklist of what I need to acquire before I drop this off to Duffee.
Engine block (duh)
Pro-gram 4-bolt caps (x2 from RPM)
Pro-gram 2 bolt front cap (x1 from RPM)
ARP stud kit
?Rear cap?
?Freeze plugs?
?Cam bearings?
Do I need to give him the crank at this time??
For the main caps......I've read that the ones Mike offers are stepped and require less machining of the stock block vs the GM caps. Is this true?
Question I have about the rear cap? Since I'm building a complete short block outside of the truck (so I can still drive around the Ty if needed), what is the part # for a new rear cap??
Do I need the cam bearings/freeze plugs installed at this time or could I have those installed when I take it back?
So I'm requesting to have the block hot tanked, checked for flaws, line bored for main caps, bored .030 over?
In past experiences, is this about $1100 or cheaper?? I talked to Duffee months ago and seem to remember this figure thrown at me, and want to know if I'm getting a decent price or not. I know Duffee is in the business of making pretty stout motors (although mainly Fords....:squint: ) so I am willing to pay a little extra.
What about having the block filled? I haven't read much about that except that it does strengthen things, but at the expense of your engine running hotter. I'm in AZ, so is this just not a good idea??
Some extra questions (if you have the :2cents: to add, please do)
I have surface rust on the crank that I got from Brandon, is this going to be a problem?
Duffee talked about having custom pistons cut because he said that he said they'll be stronger than SRP's and should be around the same price (how could this be?)
I'm currently working two jobs so I can get the extra $$$ for this build and want to go with Duffee even though it will cost me more. He has some pretty bad ass cars out there. He said he's never built a 4.3 big-HP build, and that scares me a little. But he has a lot of experiences with the 5.7's....
Thanks in advance.
jwaller
Evil Genius/SyTy Guru
Re: Block going off to machine shop: checklist?
weather or not you need bearings depends on weather or not he's going to assemble it. most ppl dont wanna spring for a new rear cap bc it's ~$350 by itself and isnt really needed.
most machines shops like to provide their own bearings bc the ones you bring most likly wont work out of the box. seveal sets/boxes will have to be mixed and matched to get all the clearances just right.
the wont need the crank to install the main caps. but if they are doing the balancing work then they will need it sooner or later. srp's are just fine unless you plan on running 8's.
PPI Typhoon
DIY Madman
$350??:shocked!: Sheesh, it would be cheaper just to get one off a junkyard motor........
So with that, there's not much of a choice to build the second motor outside of the truck with the other motor intact and running. :( FIgures.
I am planning on having them do the shortblock build. I just would like to have that done professionally. I don't trust myself. :oops:
So then the list is:
Block
Center Caps
Front cap
Rear cap (off the truck)
Let Duffee supply the cam bearings.
jwaller
if you are going to buy a rear cap then buy billete and thats what they cost.
let them supply all the bearings and freeze plugs(believe it or not I've seen different sizes in some of these blocks)
take the crank with you so they can go ahead and mike it and tell you if it's good or not and they can also start the balance work if you give them the rods, rings and pistons. you will also need an arp stud/bolt kit for the main caps.
