warmpancakes
who has done it and how did you do it? Ive seen pipe plugs, and JBweld Im thinking of a ball of jb weld smooshed into the port to block it will be the easiest method
Thread the port on the bottom of the intake and use a flush style plug with sealant liberally around the threads, etc.
I think is a good mod to do. The only thing putting me off is any increase In emissions during the sniff test. I struggled passing this every year and had to disconnect the tan/black wire this year. Does it affect emissions much?
do you have functioning EGR?
Why don't you just pull the vac line off of the egr valve and plug the vac line? That's what I did.
the upper gets pretty hot noticeable differences have been posted on IAT temps, and exhaust gas is 4-500 degrees hotter than coolant
I suppose thats a good question, as I haven't tried it or scanned it. I have operated it with a mityvac though. All the vac lines and solenoid are still stock and I'm running a stock chip/tune. I only have diacom+ at the minute though, but do have a lead for I think datamaster.
