blow bye?
turbo7521
What would cause alot of blow bye oil coming from on top of valve cover on pass side? I made sure both pcvs are in tight! I hope its not a cracked ring ???:tdown:
Re: blow bye?
You probably dont want to hear this but 99% of the time its a hole in the piston or a cracked ringland.
Damian
Re: blow bye?
Is it the one that goes to the tb? If its leaking at the heads, you'd see coolant in the oil I'd think, or you'd even burn coolant.
