Blow off valve and overboost
ghettosled
SYTY SUPERSTORE
A BOV vents boost when your throttle blades close and the air needs somemwhere else to go other than backwards through the turbo. People using a BOV to control boost are causeing more harm to the turbo, because it varies the shaft speed of the turbine blades. Basically increasing rpm and overeving the turbo. A properly sized wg placed in the exhaust manifold is the only way to control boost.
Ian Turgeon
Cascading Inspiration
favorite quote from pizzaboy:
us:" Wanna race for the pizza? Ill start in the dirt?"
him:"no, I know what those are.. my rides slow, Im gonna get a turbo miata, use a bov to set the boost at 10psi"
us:"ok, come back then"
Tooky
Serious about performance
StonesKid, I don't have a BOV but from what I've seen and read, if your wastegate is currently properly controlling boost, the addition of a BOV shouldn't really affect it and will be a fine & safe addition. The problem is when you have no wastegate at all and try to use a BOV as your sole means of boost control.
SyTyJedi
Jedi Council
You guys are totally confused. Listen to what mike said.
Info:
-A BOV releases built up pressure into the air rather than back thru the turbo, that's it!
-A WG releases air from the exhaust and allows it to bypass the exhaust turbine of the turbo to control boost.
-A popoff valve is a valve that goes on the intake pipe and opens at a preset boost level to prevent damage in case of a WG failure or something. They are usually used as safeguards. Using a POV as a means to control boost will cause all the symptoms that Mike said.
Lemme know if anyone needs any further explanation.
Tooky
Tyler for the record I completely agree with all your definitions below. But what Mike said is this "People using a BOV to control boost are causeing more harm to the turbo". Perhaps he meant to say POV instead of BOV but that's not what he typed.
Info:
But doesn't it have an adjustment for what PSI to begin releasing boost? If so, what happens if you disable your WG and just use the BOV for boost control? That's the situation I was describing above. But if a BOV doesn't have an adjustment, then how does it know what amount of boost is proper to release?
I understand the functional difference between a POV and a BOV, but how exactly do they accomplish different things? They both sound like a valve that vents to atmosphere once a specific PSI is reached. Thanks Tyler, I know you are the "BOV Fiend"! :wink:
Mephisto
These trucks are cursed
ok i think the general question stoneskid was asking is... should he bother getting a BOV? i have also been thinkin about gettin one, but i must say i am a lil confused about what you guys are saying...
so in simpler terms... if i put a BOV on a stock sy/ty is it gonna fuck my shit up???? yes or no?
it doesnt seem smart to blow $200+ on something thats gonna end up costing me $3000+ in repairs later on...
as gay as it sounds, i was lookin to get one just as a safety mod because i heard they supposedly put less strain on the turbo, also i wanted one to annoy the lil non-turbo ricers that sound like lawnmowers, with some loud whistling! i just want to know if its really worth getting one.
_________________
Mephisto
So Cali
SY-less#1931
<font size=-1>[ This Message was edited by: DefiledSy#1931 on 2001-09-27 06:23 ]</font>
Ian Turgeon
Stock sy w/ BOV = good
In our setup, adding a bov will release boost getting caught between the turbo & throttle body when the blades are shut suddenly while in boost.
You may be able to hear it on a stock truck as a fluttering when you let off the gas. That is air pushing back through the turbo's turbine. That is where damage can occur. The idea behind the bov, is to prevent that, and prolong turbo life (and make cool noises).
So how they work?
Most have 1 vacume line that attatch to the back where there is a "baffle" of sorts inside the bov housing. That baffle is backed up by a spring. In closed position, the spring and boost pressure from the baffle & intake push the plunger/valve portion of the housing shut, keeping air from escaping.
The vacume line is attatched to a source on the motor side of the throttle body. As soon as vacume is great enough to overcome the spring + boost pressure pushing the valve shut, it opens. So the vacume souce causes vacume in the baffle to increase, pulling the valve plunger back, away from it's seal, opening the valve. This happens when the engine is suddenly let off the gas at boost, where it creates very high vacume pressure.
In manual vehicles, you'll hear it pop out a loud whistle between gears (on/off/on throttle) In automatics, you wont hear anything between gears, only when suddenly letting off the gas from a boost situation.
Some "BOV's" only use a spring, commonly miscalled a bov, should be referred to as a Pop Off Valve. Because these merely "pop" open at a certain boost pressure, do to the fact that the spring can no longer keep it shut against boost pressure. (similar to a wastegate, except on the intake side)
                      _______                 _________
                      |spring    |________|                 [
vacume           |baffle          shaft                   || <--->
             ====|            =======<->=====|| valve
                line |              __   i   __                || <--->
                      |_______|   |  n  |    |________[
                                         |  t  |
                                         |  a |
                                           k
                                           e
<less knowlagable, speculation mode on>
This is bad as a sole means of boost control because the turbo is still spinning at uncontrollable revs for lack of a wastegate controlling it.
<mathew mode off>
so:
1: wastegate to control boost
2: POV to HELP limit boost in conjunction w/ wastegate (often used as a means of "leveling the playing field" at race events and for a safty measure or to make up for a insufficient wastegate)
3: BOV to help save the turbine.
Of course, many syty people have used BOV-less trucks for many thousands of miles with no noticable turbo perfomance loss. I dont know what they physically looked like though ;P
Ok, point out my wrongs...
_________________
si means fast
Ian T
91 sy#2424 42k
89 crx si 219k
F.A.S.T.
http://www.sytyarchives.com
http://www.whereiskak.com
http://www.rev-in.com
<font size=-1>[ This Message was edited by: SyTyArchives on 2001-09-27 09:51 ]</font>
<font size=-1>[ This Message was edited by: SyTyArchives on 2001-09-27 09:53 ]</font>
<font size=-1>[ This Message was edited by: SyTyArchives on 2001-09-27 09:58 ]</font>
SyTyJedi
Jedi Council
Tooky...a BOV doesn't have a preset PSI to release at...it just senses a pressure difference and opens...that may have been what Ian said...but I don't read his posts...they suck :wink:
Tooky
Thanks guys, I didn't realize a BOV had a vacuum port to the intake.
Now I am on a mission, I want to find someone with a BOV on their SyTy and have them build boost and let off the throttle so I can hear it!!
Ian Turgeon
POV's are often reffered to as BOV's by retail. Mike here in FL was looking for one, and nobody had claimed of even hearing of a pop off valve.
that HKS Super Sequential BOV is a BOV. Thats what I, Gary S., Adam R., Tyler, Ivan, and a bunch of other people use.
requires a weld-on flange and a pipe to weld onto.. Most of us are using Bob Galla's SS pipe to provide a place to weld the flange into.
I have vents in my hood, (one, directly over the bov) and the noise is very 1: addicting 2: loud. Its a whistleing sound due to the Sequential part of it (has 2 valves in one, first one that opens whistles, second one [larger] does more of the work.)
I know gary has had is for years withought any problems, so they seem pretty relyable.
My complaints:
1: reaching under the intercooler to remove it's bolts is a major pain
2: the snap ring is a bitch to put on (make sure you install from the bottom side so you dont see the scratches on the bov body)
Tyler.. I dont read my posts either so I dont blame you
MikeDee
I am planning to get the HKS Super Sequential Blow-Off Valve, but I don't think I can put it in myself. Need help. I'm no mechanic but I don't want some idiot messing up my Ty-if thats the case i'd rather do it myself.
Is there anyplace that I can take my Ty where they know whats up? I don't want to take my Ty to some dumbass who thinks he's working on some cool blazer with a turbo.
G
Guest
Guest
I'm thinking of a BOV in my stock truck too for safty reasons. Let me know what the best unit is and what to expect during installation.
Ian Turgeon
Installation is simple if you go with Galla's ss pipe.
mark for the hole on the pipe, take it to a shop that can weld the fitting on.
Then sit it in a vice and install the ssbov with a pair of snap ring pliers.
bolt the tube in place on the truck, and run the vacume to a "t" off the manifold.
This is a simple thing to do. If you ever want to learn how to do anything mechanically, you have to start trying.
