Blow Off Valves for a Typhoon
Rick_From_Mi
Is there any place that offers a B.O.V. for the SYTY engines? If so does someone have a link. or if not could someone explain why.
Thanks!!!!!!
-Rick
TheObiJuan
there are no companies that sell bov's for syty's. however all you need is a hard pipe from the turbo to IC and weld a flange on it for the bov.
some people like the greddy type s and the hks ssq. (super sequential)
since pictures speak louder than words on the net, here you go:
and even better than pics is video. here is the greddy type s in action:
http://www.directcon.net/rabies/mysy/syclone.avi
TheObiJuan
performance...not really. it just lets the turbo take a break. it is a *safety* mod that keeps the air from stressing the turbo when the Throtle body closes.
do it to be safe, look cool, sound cool.
ed hess
race or get outta the way
A BOV im my view is as much a safety item as your brakes, shaft loops, cage and helmet. Who wants to trash 10k in a motor. Where did the pipe in the pic above come from?
ed
Fade to Black
Is there a place that sells those pipes to the intercooler already made? I am looking for one just to replace my stocker. Also, do you just bolt the BOV up or do you hav to run a vacuum line to the top, I can't tell from the pic...
TheObiJuan
go to an exhaust shop to get the bend.
i will see what i can do for you as for the flange and the small pipe that attaches to the bigger pipe. i will have a friend of mine hook me up to help you. all you need is a vaccum line from the top barb t'd into the vaccum system.
InvisiBill
When you have it floored (throttle wide open, 15psi) and take your foot off the gas (because some old bag pulled out in front of you or whatever), the throttle blades slam shut. The turbo is still spinning and making pressure. That has to go somewhere, so it's forced backwards through the turbo and out your intake. If you go to an open filter, you'll be able to hear it "fluttering" like a horse's lips.
A BOV is a vacuum-controlled valve between the turbo and intake. A line hooked to the intake tells it when there's a difference in pressure (i.e. turbo-IC line under high pressure, intake in vacuum, due to the throttle slamming shut). It then opens up, and vents that extra pressure out to the atmosphere. IT ONLY HELPS WHEN YOU LET OFF THE GAS. When you get back on the gas after that, the turbo won't have been slowed down by the backwards airflow, so it should spool up again more quickly. This is a bigger deal on manuals, where you're on and off the gas between every gear. It will help your turbo last longer, and let it spool up more quickly in on-off-on situations, but it's mostly just a turbo-saver on our trucks. FWIW, I could feel absolutely no play in the turbo of my stock Sy with 124k on it.
Fade to Black
thanks man, let me know what you find out. I am wanting to replace the stock piping from the turbo to intercooler, and might as well do the BOV anyway. I appreciate your help! :D 8)
TheObiJuan
np. i spoke with him and he is making the flange and pipe for you right now. i will sand it and paint it and take it to d/fw some time soon..
Fade to Black
damn, that is some fast service, thanks alot! :D Let me know how much I owe you. Feel free to e-mail me anytime.
Speaking of which, I may be in College Station within the next couple of weeks visiting my friend, if so I will let you know when I am coming and maybe you can check out my syclone.
TurboRob
Junior Member
Here's an example of the HKS Super Sequential BOV that was mentioned, installed with a polished stainless pipe.
SyTyJedi
Jedi Council
I have some pics of the HKS BOV that was on my Ty that I can post when I get home. If we could start class a little sooner right now that would be great. (in school right now)
I'm thinking of going to 2 HKS BOV's when I get my new setup finished. A friend is trying 2 BOV's on his big turbo WRX. He's getting a different insert for one of them to see how it sounds with 2 different tones coming out of each valve. If I like how that works I'll do it for the Ty as well.
I guess if I did have 2 they would still leak under boost from the bigger turbo eh? Might as well just get the HKS Racing BOV and be done with it.
8)
