Ok, just for my 2 cents in, all the blower speeds go through the relay, just the first 3 speeds go through the normaly closed contact of the relay and the high speed goes through the normally open contact of the relay. When you select high speed, the relay actuates, bypassing the resistors located in the heater/ac housing, and connecting the blower to a circuit that goes to a fuse link, connected to the battery, thus taking the big current draw off of the switch in the dash. The switch in the dash will go out occasionally, burning up the contact and sometimes taking the connector out with it, also. usually when this happens, you have nothing but high speed or no speeds. The new relay I got from napa, had a diode internally installed backwards, so that everytime I put the switch in high speed, it would blow the 25 amp a/c heater fuse. Make sure you mount the relay back just like it came off, cause if you install it upside down, water will eventually fill it up and cause problems also... Steve.
