Blown ECM B Fuse after AFPR Install
Ty1642
I just installed an RPM AFPR in my Typhoon. Set fuel pressure to 45 lbs with the vacuum line to the FPR disconnected. While I was installing the regulator I removed the ECM B fuse. After putting everything back together, the truck idled and ran fine. After a couple of miles of the test drive though, the ECM B and ELC fuses blew.
Is there a reason the AFPR install would cause the fuses to blow? The only other mods are an ATR aux intercooler w/ Johnson pump (been on the truck about a month) and a throttle body airfoil I put on while installing the AFPR (shouldn't have anything to do with it). When I replaced the EMC B fuse it started back up without a problem.
Appreciate any help. Next step is to install an Ultimate chip as soon as this gets sorted out.
syclonekid43
i would check for a pinched wire around where you worked.
on my 2.8 (yeah i know 2.8) blazer. the same fuse kept blowing on me. come to find out when i put the air cleaner back on. i pinched a wire between the TB and the cleaner. caused the injector to ground out and blow the fuse.
