Blown ECM Fuse?
SPEEDFREAK
Driving around today and both ECM fuses blew any idea what could have cause that? What can I do to figure out why?
SY2455
70's Veteran
Re: Blown ECM Fuse?
You may check your Intercooler pump. Did they blow right away when yoy replace them?
Loeryder
Re: Blown ECM Fuse?
Fuel pump is tied into ECM B.
Put a higher amp fuse in it and be done.
I think mine has a 15 in it now, but some run 20A wiht no problems.
Aftermarket pumps draw more current or if you still have a stocker excessive current draw can mean it is dying.
Timbo
SyTy Stalker
Re: Blown ECM Fuse?
So then, if my fuel pump works, does that mean that my ECM B fuse is still good?
SPEEDFREAK
Re: Blown ECM Fuse?
Well I pulled out to pass some one and got to about 5psi, not beating on it just normal driving, when it got to about 5psi, it spark knocked and blew the fuse, replaced it then went a little further and it killed the ECM B fuse, replaced it and nothing since. I put 10 amp back in both should I put 15's?
SY2455
70's Veteran
Re: Blown ECM Fuse?
This happen to me on my test drive when I was looking at buying my truck and it turn out that the intercooler pump burn up getting on the freeway. The prior owner replace the pump before I pick the truck up.
