Blown fuses
92 Ty 1173
Has anyone had a problem with the ECM-1 fuses popping after installing an ultimate chip? The fuse has blown twice with 10 amp fuses. Both times on an 18psi pull. I put a 15 amp fuse in and it has been ok for now. Thought I would ask in case I need to chase some gremlins.
KETCH-UP
Re: Blown fuses
I think that fuse powers the fuel pump also. If you changed out the pump, the new one might pull more amps. Somewhere on the site is fuse info, or search some old posts to confirm.
