Blown Turbo Bearings???
5SpdTy
ok so i was driving along today and all of a sudden my boost shut down and the turbo started making this horrible noise. it was a mix of scraping metal and a screaming whistle. if i rev up the engine sitting still it doesnt make the noise, but if there is a load on the engine and i give it more than half throttle it makes the noise. i drove it home cause i had to, but im abviously not gona drive it till i find out how to fix it. if anyone can try and help me id greatly appreciate it cause i am learing about these trucks as i fix stuff on mine. thanx greg.
berzerker
wookie
Re: Blown Turbo Bearings???
pull off the intake tube on the front of the turbo . look at the veins ( fins ) on the turbo
should 'nt be any bent or broken . grab shaft and wiggle it ,up ,down, in out . should the shaft have play you turbo is most likely toast. good luck !
5SpdTy
yea the turbo moved every way, its def blown. jwaller is helpin me out with gettin me another turbo.
