Bolt on 4/5 Link Setup
jklein68
Trying to figure this out...I have access to a waterjet and a welder, but am not a chassis expert. I want to make sure I am not missing anything obvious.
What about fabbing a bolt on four link setup that uses the existing leaf spring mounts on the frame, front and back....
Benefits
1. Fully adjustable ride height.
2. Fully adjustable rear end.
3. No need for Caltracs or battle bars.
4. Much better rear grip.
Facts
1. Each link would have to be adjustable.
2. Each link would have to pivot at both ends for vertical travel.
3. Coil-overs would mount in the stock shock location.
4. May need a fifth link for horizontal travel.
Sportmachines
Re: Bolt on 4/5 Link Setup
Without letting the cat out of the bag..... we are already in the middle of working something like this out for a Syclone. we will have pics and info once some details get worked out. But your benefits and facts are spot on, and what we were thinking when we started to work on this.
RealFastV6
@jb_and_his_coffee
Son of a.... so you're saying I shouldn't order those beltechs and caltracs? :squint:
Sportmachines
lol....I"m not saying anything..... until we have a full blown working prototype. But you may want to hold off..... ;)
Beavis
Still plays with trucks
I would love to see a ladder bar system that used the stock front leaf mounts. And maybe some type of link that used a large flange on/under the diff cover to go to the frame for left/right antimovement. That could be a sy and Ty item and not for just one.
The rear mounts won't do you any good for a proper suspension design. Fronts yes.
Lots of options, should you design something just know about instant centers, roll centers, etc. If you understand that terminology you should have no problems improving on stock.
jklein68
Definitely an easier design, would that be enough?
jklein68
Thanks! I will research this and post back to here.
jklein68
Update: As stated by Sportmachines, Tom and crew are working on this already. Hopefully any feedback and suggestions will help them with their design.
I look forward to the potential announcement. :tup:
:popcorn2:
elorejas
in for one of this when there out in the market
fivetodrive
CRISPY
Dosen't Robert use an old dustan setup that mounts to the leaf spring mounts? I cant find his gallery...
Found my old post from 2008 with pictures but I just have the rear mounting pictures...
Hey thanks! It looks like you are right!
After looking at all of the pitures on Robert's site here it is...
And here is your picture of a Dustan setup...
I don't know of he still uses it but yes Robert did have a modified Dunstan rear suspension at the Nationals when he was here in 07.
It has been removed and something different installed (all i can say). 1 problem with the Dustan setup is it was very unsafe for a couple reasons.
ANY ladder bar suspension must have a safety hoop on the front pivot. You can see the safety setup here in this off the shelf kit.
The brackets on the rear end, also had some problems in strength, and possibly the heim joints used.
Suspension is not a piece on the truck to be skimpy on. Failure of these components can be deadly and must be treated with much respect.
sy605
:tup:
Windedv6
Ty n 10s
I originally had a dunston rear ladder on AWD Ty back in 2002. It was positioned in the front spring eyelet. The problem with that location in that is directly under the frame at the axle location which limited the axle travel. Mine broke because of bad welding on the axle bracket. I changed it out to a Competition Engineering kit in 2003 and it works like its susposed to. The bars are longer than the stock spring location and helps with the IC.
For launching an AWD, it is still better to keep the front wheels planted vs spending the energy to try to lift the front. Unless your wanting the ultra stable ride and cornering of coil overs, stay with leafs and Caltracks for traction for AWD.
John
