bolt size for JS pads?
jjorgensen52
NHSTE - I'm the only one!
What size bolt is supposed to be in the JS frame pads for solid motor mounts? I assume it's a grade 8 or 12. Haven't had a chance to check so I thought I'd pick your brains instead :tup:
Re: bolt size for JS pads?
7/16" x 4". I don't think you will break any grade, but to be safe grade 8 helps.
MRKING
New Parts for Old Trucks
I used the stock bolt + couple washers , you cant even see them .
jjorgensen52
One of mine was broken and the other one broke in removal :roll: ... Thanks Jeff :tup:
