bolt size for oil filter adapter
THEMADTYPH00N
I need to know the size & length of the bolts that hold the oil filter adapter on the block. I seemed to have misplaced mine. Thanks
Re: bolt size for oil filter adapter
A truck that doesn't run doesn't need that bolt, just ignore it.
EcSy#2671
Si vis pacem, para bellum
I have the bolts out of my block right now, when i get home from work I will check for you.
Erik
THEMADTYPH00N
So is that why your truck isnt running either?
GM TURBO said:
It should be the same size as the one you lost.
Thanks captain obvious!
Erik
Thanks
EcSy#2671
They are 3 1/8 long 1/2 head with washer head and a 5/16 shaft size. if that helps
