Boost control and WGDC%
Awdsyty
Is the F71 scale in Programmer the only factor that controls the wastegate? Here is my problem. I had custom chipping done last year and my boost control was rock solid. Over the winter I had the dozen or so cracks in my ATR headers repaired (crappy welding from ATR). Now I have severe overboost. Can I just adjust the percent of the WGDC in Programmer to correct this problem? I assume if 100% is closed, then say 0% would be open all the time? My values are about 60% now. How much does a percentage change make? Should I try 20 or 40%? I have a 20G with a ported wastegate and a Hahn high boost actuator if that helps. TIA
Darrin
That table is the one I would change..
I have noticed small changes can make big boost changes...
Maybe go 50%, then adjust from there...
BillC
F71_SCALE does NOT control boost. It only controls the source from which the computer gets the value used to index the F71 Table. So, if you want to scale boost control against TPS or MPH, then you would modify F71_SCALE.
If, however, you want to change your initial wastegate duty cycle values, you need to modify the F71 Table.
Before you start mucking around with this table, you should REALLY get DataMaster or Diacom, and RECORD SOME RUNS!!!!! I can't emphasize that enough! After you have some recorded data, look at how much the duty cycle values drop after each shift. That's the computer trying to control the boost spike. As a start, try setting the values in F71 to about 5-10% lower than the lowest after-shift duty cycle.
