Re: Boost control solenoid
if you still need to drive the truck you can take a piece of line off from where the solenoid gets its source (right off the compressor housing) and run it straight to your wastegate actuator. This will give you base boost, so that you can still drive it and not overboost it. Your performance will suffer, but you will make it to work. i would also say just to be safe to ziptie the lines on as tight as you can, just as a safety measure so that they don;t blow off (all my lines are)
