Boost control valve ?
Neelsonwheels
I was trying to figure out a high idle issue which only show itself when the truck is warm.
I posted pics of the new setup this morning and went out to trace the vac lines. When I started tracing the lines from thr greddy control valve to the turbo I found the line was severed just shy of the clamp. I checked both lines the one that was cut and the one to the wastegate. Both seemed fatigued so I replaced both. Could this cut line be the cause of a high idle? Also I am pretty sure this was the reason I had limited boost. I appreciate any input guys. Also any help with finding a tuner of Bigstuff I would be forever thankful.
Jeff
5678TA
Re: Boost control valve ?
the boost solenoid only controls spool up speed and total boost psi. your high idle is from something else. check timing perhaps?
Neelsonwheels
I'll take pics of the valve.
It says greddy right on it.
The lines go from the valve to the turbo and from the valve to the waste gate.
I have a greddy boost controler in the glove box. The truck is controlled by bigstuff3.
Quickstop [UK]
Combating adversyty.
I have the Greddy same as you (Spec BII?) and if you have no air going to the wastegate then you'll get low boost.
