Boost controler and Turbo timer
BOOSTED92TY
I just ran across a good really chep deal on a turbo timer and a boost controler is there any need of putting this on a stock setup truck? i can get both for under $100 from a friend?
SeattleSy#1255
Category 5 Conservative
if you go with an boost controller, then i'd aslo go with an external gate...the stocker wg stinks and is a weak point. I don'[t thinkn many have had any luck with better control with just a BC. turbo timer, umm whaterver if you think you need it.
SyTyJedi
Jedi Council
Which brand of boost controller? turbo timer?
HKS and Blitz are the only electronic boost controllers worth getting IMO.
That is up to you and what you want your truck to be. I like the ability to dial in my level of boost without leaving the drivers seat and I like the features of a turbo timer - so I have both.
KGB Pilot125
i would have o disagree with you, I think that the ITS multistage controller is the best electronic boost controller ever made. i just wish it was a bit thinner so it could fit in a DIN slot.
spooldup
Super Member
I ran a greddy profec b on a stock gate for a while and it worked perfectly all the way up to 20psi wich was the highest i went at the time. My current setup still uses the profec and i have taken it up to 23psi with no problems at all. I reccomend it.
