boost controller
Ryda85
Senior Member
is it worth it to buy a boost controller if i am running a stock turbo with the stock wastegate? or do i need an external gate?
wantingasy
Re: boost controller
What would be the best electronic controller for a stock setup? Stock turbo/internal wastegate. Do you adjust the amount of boost by just pushing the buttons and looking on the screen then? I've never used an electronic boost controller so bare with me :oops:
Ryda85
Senior Member
so no go on the boost controller with stock turbo/wastegate setup
wantingasy
In the stock setup, boost is controlled by the ecm. The black thing you're referring to on top of the turbo is the boost solenoid.
NeedaSY
Go Ahead N Go
Do those go bad bad any chance cause my turbos boost is weird noise since the lil vac line from the wastegate came off??
wantingasy
I was reading your post about that. I highly doubt it would go bad just from the line being disconnected for a short amount of time unless something got clogged in it. Probably wouldn't hurt replacing it though especially since you just bought the truck. You know what you have then :2cents:
Edit:: I see you picked up an AFPR huh?
NeedaSY
Go Ahead N Go
Good point thats what i have been doing with everything else on this truck might as well. but i think i am goin to try a blow it out with an air compressor first to save money for the time being.
No its acutually its been there since i bought it its just that i forgot to put it in the sig.
NeedaSY
Go Ahead N Go
I havent realy been doing anything performance why's to the truck yet just been fixing what was already rigged up inless you count eliminating AC.
wantingasy
Same here. I bought mine in January and I haven't had to replace anything major yet, but have been going through and changing a bunch of little stuff.
live1053rulz
Nor Cal SyTy
I got the Blitz ID 3 electronic boost controller. It's really pretty cool. I like it. Now if my truck would only make more boost...
