Boost gauge line install
TyGuyJeff
I am having some difficulty routing the hose for my boost gauge. I didn't use the crap thin hose supplied with my autometer boost gauge. I upgraded to 1/4" hose and it work great when hooked up to the gauge, but now its time to get it back in the pod, and hose out of the way. I was wondering if anybody has encountered problem with the thicker hose, and how should I get the hose to the gauge after it goes through the firewall.
Tooky
Serious about performance
I haven't installed my own gauges (previous owner did) but here is my opinion. Stick with the "crap" (as you put it) small line that came with the gauge. If you have a big line it will take longer for the boost signal to reach the gauge. The smaller the line, the faster the signal will reach the gauge. The guys at Autometer know what they are doing. What is your reasoning for using a 1/4" hose?
mrweelr
I used the thin "straw" type line that came with my Autometer boost gauge. Ran it from the plenum, through the firewall, all the way to the gauge in the pod with no problems. Can't comment on the thicker line but the stuff that comes with it works great as long as you don't bend or pinch it.
TyGuyJeff
I didn't want to melt a hose, that could be messy. I was gettin some help from a 10 sec GN owner and he told me he's melted the stock "string" hose on both his modded WRX and GN. I really think I need to remove the dash to do it right. Any suggestions?
ed hess
race or get outta the way
run the line between the A piller and the dash. If you lay a drop light underneath the dash and look down through the windshiled you can see you have plenty of room there! ...assuming your putting it in a pod on the pillar.
ed hess
vin no 00045
TyGuyJeff
Thanks for the tip, I'll check the clearance tonight after work. I hope my upgraded hose will fit, but then again, anything is possible if ya put your mind to it. I'll post when I realize my luck or msifortune...
Quickstop [UK]
Combating adversyty.
Re: Boost gauge line install
any joy with this? I can't seem to see a route through. I know there is one - guess I am not as technically proficient!
James Thomas
"NO CLASS"
I agree with TookyCat on the supplied 1/8 nylon tubing. It is a slower response time or lag on the reading using 1/4 hose and it is not as sensitive to minor luctuations of the guage reading. If it's the melting problem you are worried about then don't. That nylon tube is within 80 deg. or so of the rubber hose melting point it sounds like you are trying to use. If you melt any thing at all, it's because it was routed to close too a heat source (exhaust/turbo). We have used the 1/8 nylon for years with no problem, if routed correctly. Also don't tee into the vacume line for the map sensor or fuel pressure regulator, that is a big no no.
Admittedly, any standard rubber hose or nylon tubing will have a limited life span at normal under hood temp. It will last for several years before getting "crispy" and starting to crack but all cars have this problem especialy or trucks due to the extra turbo heat. Don't want to use the nylon tubing that came with the Autometer gauge even though it is a higher rated heat resistant nylon? Then use the silicon tubing that is even better. But beware, if you run it to close to the exhaust it will melt also.
_____________
James Thomas
Island Cylcle & Performance
Mariana's Motor Sports
J&J Auto & Industrial
Quickstop [UK]
once you have dropped the line (I am using the autometer stuff) behind the dash, how do I get it through the firewall?
Considering I am putting in a fuel pressure, trans temp, AFR and boost gauge, is it worth just drilling a hole or is there one that is suitable for all of these? I'll use the grommet once I'm through...
Thanks in advance.
James Thomas
"NO CLASS"
Thanks in advance.
A nice clean hole with a grommet will wok fine :tup: .
_____________
James Thomas
swoop
under contruction...
where do you drill? Or is there a spot from the factory you can tap into? I'm actually having the same problem cause this truck has no boost gauge since its not an original ty.
Quickstop [UK]
just been told there is a plugged hole under the master cylinder that is available. i think I am just going to drill a hole near the top of the firewall big enough for all my sensors. Will have another look at the hole and see if I can use it though, but will post pics soon. (I hope!)
turbodog
When I had a mechanical fuel pressure guage (yes, with an isolator) I was running 4AN braided hose into the cockpit. To do this, I drilled a hole thru the firewall right at the base of the a pillar, under the wiper cowl. Then the 4AN hose ran up thru the driver fenderwell, under the wiper cowl, and directly into the bottom of the a-pillar. I since ditched the mechanical FPG, but now have wiring for 8 electric senders running thru that hole. I ran the boost guage spaghetti tube thru the grommet under the master cyl.
To prevent water entry thru the hole I drilled, I use the pliable petroleum-based sealing goo (I don't know the real name... my Grandpa, who taught me most of my wrenching skills, called it 'monkey shit' so that's the only name I know for it).
vinnieTy
TY # 1889
I didnt have to drill a hole at all. There is room and grommets under there that will work with a little thinking. The only problem i encounterewd was that i put a pinch in the line but besides that the tube worked out well. Does anyone have a spare clear original tube that came with the gauges that they want to get rid of. I have tried a few autoparts stores and so far no luck.
thanks
Quickstop [UK]
aaarrggghhh! I can't seem to get anywhere!
I thought about drilling under the wiper cowl, but can't get the wipers off. Any tips? I see there are some spring loaded locking clamps on them.
Once I have those off, I can take the wiper cowl off ok?
I hear ya vinnie about not drilling.. I just wish I could see a way through. I know it's there!
I found a blanking plate on the bottom of the A pillar - I am hoping I can get trhough to the engine as it was sealed on there with what looks remarkably like monkey shit!
vinnieTy
TY # 1889
Just keep in mind if you do drill a hole you need to get a gromet. Usually it is a plastic gromet that will pop in the whole that you made so the wire or tube what ever you are putting throw the hole does not get ripped or torn from rubbing on the metal. That is why i would recommed lookin at some of the wires going throw now and just squeeze it threw. Of course just my two cents but it sounds that you are going crazy. It took me about 15 minutes to find a spot and run the tube. Of course a few more minutes wiring the gauge up for the light but that is about it.
