Boost Guage Light
How do you recommend connecting the boost guage light. I would like to have it come on when I turn the lights on, not when the ignition is on. I was going to pull the light switch out and see if I can find an easy connection in there. How do I remove that panel? Does it just pop out?
InvisiBill
Ian posted this when I was installing my boost gauge...
sy2185
Tap into the wire going to the fog light switch. The gauge light is real low draw and won't overload the driving light relay trigger at all(I have both gauge lights on it). That way you can have the headlights on but turn off the driving lights and the gauge lights die too.Plus, no new wire, no new switch and the wire's even easier to run.
Jeremy
helfmann
Tap in the light switch.
Pops out easy after you removed the two screws of the fog light and the other two underneath. Just TAP it, the advantage is, it does not only light up switching on you lights, you can dim it with the regular dim switch.
M@
http://www.tyguy.net ---> Warning strange language
