boost measurements, 2bar to 3bar conversion table
SY732
Here is the little list I have stuck to the laptop for HG to PSI (3bar)
I can send the xls version if anyone would like.
HG PSI
34 25.1
33 24.3
32 23.6
31 22.8
30 22.1
29 21.4
28 20.6
27 19.9
26 19.2
25 18.4
24 17.7
23 16.9
22 16.2
21 15.5
20 14.7
19 14.0
18 13.3
17 12.5
16 11.8
15 11.1
14 10.3
13 9.6
12 8.8
11 8.1
10 7.4
9 6.6
8 5.9
7 5.2
6 4.4
5 3.7
4 2.9
3 2.2
2 1.5
1 0.7
Ian Turgeon
Cascading Inspiration
chris, ill put that up there too for others so its easy to print out.
christian..its a table, its easy to read.
this is based on boost pressure output for diacom/datamaster
not the absolute kpa (which includes barometric pressure)
so if your dealing with the absolute read out (including at press)
1 bar = 100kpa = ~ 30in-hg = 14.5psi = typical atmospheric pressure
add 100 kpa, 1 bar, 30in-hg, or 14.5psi and your at one bar above atmospheric, one bar of boost
add antoher 100... you get it
If speed pro has to do the same conversion bg did to trick the ecm into recognizing a 3bar, this should work for that.
someone set me strait if wrong.
(christian)
200kpa (total) is 15psi on a 2 bar... 22 on a 3bar conversion
smeagol
Everyone is confused because we are talking about 20 different things.
Actual pressure in the manifold
Absolute pressure
boost pressure
Diacom readings
3 bar conversions
First off, actual pressure in the manifold. A boost gauge is referenced by atmospheric pressure, giving you a boost pressure reading. Absolute pressure is referenced to vacuum. So 200kpa = 15psi of boost, when it is ~30psi of absolute pressure.
Diacom readings are sorta accurate for 2 bar (enough for reference) but way off for 3 bar. So you need to do a conversion from 0-200kpa (which it thinks the range of the sensor is) to 0-45psi of absolute pressure, or 0-30psi of boost pressure.
So some clarification is needed on the tables, and they should be clearer.
Ian Turgeon
I made some changes, and added 2 hg-psi tables like chris suggested.
hopefully I made this a little clearer?
also, brian cleared up my question about speedpro, there is a setting to usilize a 3bar map, so there is no conversion needed by the user to understand pressure readings reported by the computer.
Mad Mike
SYCOSIS
Let me ask. I just removed a aftermarket boost gauge from my ty but I still have the ultimate plugged in. How does the ecm interpret 3 bar readings and then send them to the stock gauge? It seems the most boost I show on the stock gauge is like 5-7 psi no matter how much boost I give it.
Ian Turgeon
you can get an idea by looking at the first table how the stock boost gauge is going to display boost.
Look at the 2bar psi value the stock boost gauge is displaying, the real psi is the 3bar psi value on that same horizontal line.
10.15psi(2bar) = 15.18psi(3bar)
smeagol
Stock computer doesn't send the signal to the stock boost gauge. It is straight from the map sensor basically, so 0-5v = full swing of the gauge, that's pretty much it.
