Osmosis
I've been tuning the chip in my ty for sometime now. I'm finally getting close to perfecting my tune. I’ve noticed that my boost pressure was surging between 19-22ps. I could actually feel the surge in pressure during my runs at WOT. I can seethe surging in my tuner pro logs too. Kind of a saw tooth appearance. I had my internal waste gate arm almost fully tightened and I’m using a boost valve with the higher psi spring to control my boost pressure. I decided to "properly adjust my wastegate spring and slowly increase the tension to see if I could remedy this problem.
I loosened the waste-gate actuator arm to the proper adjustment (7/8 of the arm covering the hole). Went out for a drive and my boost was climbing past 22. I put the lighter spring in the boost valve and completely loosened the boost valve so my pressure should have been aprox 12-13psi. Nope, boost pressure shot Straight up to 25psi??? I put my stock boost solenoid on the truck. I held 12-13psi steady for a bit, then my boost pressure ra suddenly climbed over 20psi, so I pulled my foot out of it. I then reversed the vacuum lines and I got a solid 11psi. Pulled it into the garage and I replaced all vacuum lines. NO change. I then tightened the wastegate actuator to the 1/2 way point of where it initially was. No change.
I've no idea what's wrong? I’m guessing my wastegate spring actuator is bad?
HELP
:rant:
HELP
