Boost pressure
Re: Boost pressure
That is normal for the boost look like a rollercoaster. Target boost in the ecm is 13.8psi.
Syclone22
Re: Boost pressure
It is possible a weak actuator spring pressure
but it can also be the boost target setting from
the ecu controller to solenoid !!
Typhoon-Dennis
Re: Boost pressure
is it useful to work with an external Wastegate and an boostcontroler with a stock Turbo?
Or does this setup works good with an other turbo like an 20G?
berzerker
wookie
Re: Boost pressure
does it still have the factry cat on it ? put a high flow catalytic converter on it and it will maintain boost levels
Re: Boost pressure
The boost control can be flat if you change the settings with code59. Gm control system programming is over damped.
You can use a external wastegate with stock turbo. I know owners who had good luck with flat boot control (you can also remove the cat and still have good boost control.)
I used a high flow cat and my boost control was flatter however the boost crept up on long run 3rd gear to 16-17psi even if I disconnect the boost solenoid (should have been 9psi).
Re: Boost pressure
Hi
I got stock turbo - waste gate and cat :D
