boost sensor location with innovative msbc and testing
ed hess
race or get outta the way
so i got this thing installed.
put the innovative boost sensor on the map fp vac line.
In the innovative schematic they dont actually say where to put it with a single actuator style wastegate like the pte.
Anyway i go out to test it.
I get 2 psi higher if i have the dump open.
No surprise here as this is this is the same thing i found without a controller and the dump open.
Since the local interstate is under construction i couldnt do a launch to test as there is no way to pull off cuz there is no parking lane, unless i drove another 10 miles, but i didnt have enough time....
so anyway, using 3rd gear from 50 mph up to 80, with the thing set at 16 i would get a quick spike to 20psi. Then it would immediatley come back down to the 16-17psi. This is with the dump closed.
with the dump open it would spike to 21 and then come back down to 17-18.
The spike was much like you would get if you have ever run a manual bleed valve for boost control and nailed it in OD on the highway.
Intial spike and then it would come down and be controlled.
Since i have the block oringed and some fairly good hardware I have 2 choices to make my runs tommorrow at the track.
1 just go to the track set the controller for 19, and with the dump open i will get a controlled boost of 21.
But i doubt i will see a spike since boost from a launch doesnt have that initial spike like you get on the highway as the tc gets to its lockup.
DOES THIS SOUND CORRECT OR MORE OF A WAY TO BLOW IT UP?
2. at midnite tell the wife im goin out for smokes and head up to the far reaches of the interstate and launch this sucker when theres no traffic.
seems to me this has the same effect if im wrong as in number one above but it doesnt come with a timeslip. :D
I tell you what though. This son of a bitch felt like somebody elses truck when it hit 20psi with no knock counts!!!
Allmost like being on a damn runway in a plane. :D
ed hess
oops
think i might be on to something here...but maybe somebody who has one of these can jump in.
I hadnt set the ramps on the controller. It appears that perhaps the default value of 40psi/second was to fast for a ramp. especially since the controller was then able to contol the boost after the initial ramp was over. So i just lowered the ramp to 20psi/second. tomorrow i will see if this does away with the initial spike.
If not then perhaps the next ramp setting lower?
anyone else ever program one of these?
Interestingly enough. i had done my testing with the tc lockup switch off.
the initial spike followed the rpm jump you get as you go from cruising rpm to stall rpm as the tc locks. Once the load is on the spike goes away.
Becuase of this i dont expect to see a spike at the track tomorrow nite since the load is allways on.
hopefully i am comprehending how this thing actually works.....
ed
