boosting 24 psi on two bar?
REVEREND HARMON
Party in a box!
I got on the typhoon today for the first time after going through the motor and putting the whole truck back together. I got on her on a back straight away and it felt awsome, anyways i looked at the boost gauge and it topped at 24 psi. So on my way home i tried it again and sure enough it boosted up to it again. Now im pretty sure it has a 2 bar mapp sensor on her but i also have a pittbull chip in it that came with the truck. I read a similar post by someone else with the same chip boosting 20 on a 2bar. Is this possible? Looking for some insight before i accidentally blow her up and have to start over because of a bonehead move.
Trapper
Re: boosting 24 psi on two bar?
I thought 93 octane was really only safe at 15 psi, or you can have a bad day really fast. Something must be wrong. Maybe the guage is bad?
REVEREND HARMON
Party in a box!
The gauge worked fine before and its in sync with the stock gauge. when you turn the truck off it resets back at zero. Its them dang gremlins. Not to mention it is alot faster now and you can hear the turbo spoolin up higher with the gauge. Im runnin 93 in it with some handy dandy octane boost additives.
Im at a lost.
willyson
trollin'
internal wastegate boost spike. get a scan tool to watch your knock in case it might cause damage
It's just a six
Super Member
I used to boost to 18 psi w/a street pittbull chip & it would boost spike momentarily to 20-21 on the shifts.
That is how it ran when I ran 12.29 & 12.31 back to back. No methanol injection .
It was not lean either.
Knock count was low just on shifts point only.
MRKING
New Parts for Old Trucks
Lay off the high boost and the 2 bar map . It cant tell if your motor is running 16 or 26 . The 2bar only controls the fueling up to 14 psi , anything over that and its just leaning out the higher you go until boom .
Now if you in fact have a 3 bar , youll be fine .
REVEREND HARMON
Party in a box!
Ive got a laptop with datamaster but i cant figure it out. "im dumb":banghead:
MrKing, you workin on yur truck this weekend? Maybe i can get ya too give me a lesson on datamaster, PPLLLLLEEEEAAAAASE.
24psi? Damn.....:dropjaw:
Is that with the stock turbo. Your waste gate is stuck shut or something. What boost where you at before? Better be careful. I cant run 20 psi on the stock turbo without alky injection.
REVEREND HARMON
Party in a box!
LOL
I now its not a stock turbo. Actually i dont know what size turbo it is exactly because it came with the truck and the guy i got it from had no clew and the owner before him on this forum isnt very helpful. There is no numbers or markings on it at all. Its one more thing i have to research on my own like everything else on this wonderful truck.
jpalmer
just be careful, you got it looking really pretty, it doesn't need to sit due to a blown motor
Trapper
Second on that, I see these little turbos we have on the SyTys they don't make them as well, Mine had a little ingraving on the top T60 and thats it.
GM TURBO
Sell Out
If your aftermarket boost gauge is in sync with your stocker - you have a two bar MAP.
You don't need a 3bar MAP to run more than 14.7# of boost. The FPR will handle the basic fueling needs - 1# of fuel pressure per 1# of boost.
But, you do need a 3-bar MAP, calibration and some datalogging equipment to do it safe. You can not run a 3-bar on a 2-bar calibration.
turrrbo6
I still have the broken rod sitting on my workbench as a friendly reminder of 20+ psi on a 2bar
REVEREND HARMON
Party in a box!
i definitely dont need a reminder like yours! Nope Nope. Ill figure out datamaster i guess. its a pain in the ass.:rant:
MRKING
I just got in from work and today we are hitting up busch gardens for a good half day trip . Our year passes are almost up , got to get the $$$ worth from them . I'll call you later when we get back .
You guys going to halloween horror nights or hal-o-scream this year ?
ATR used an open loop boost control. It basically open the wastegate with preset electrical pulse to open and close the wastegate solenoid to bleed off boost. The stock closed loop boost control adjusts the electrical pulse. If your using the stock solenoid and wasteragte with the ATR, you can adjust the wastegate rods to adjust the boost level (assuming no vacuum leaks). A longer rod make less boost, shorter rod make more boost. I would check the condition of the vauum lines and lengthen the rod.
