boostvalve dual mbc
vortecfiero
Re: boostvalve dual mbc
what do you guys think of the 2 stage mbc from boostvalve.com? im really liking there deluxe 2 stage setup.
http://boostvalve.com/pricelist.html
for that kind of money you can tune the stock setup to do anything you want
based on rpm, throttle position etc. (depending on your build of course)
and still have full knock retard etc on your boost controls when things
go wrong.
low buck version
put a waste gate on with the minimum setting you want.
the stock one is 7lbs.
tune the system for everything else
put an on/off switch on the waste gate signal from the ecm
switch on = ecm controls
switch off = min boost determined bye the waste gate
Slowcone
i really like being able to change both levels on the fly and not have to play with the wastegate when ever i wanna change my low boost setting. the turboxs dual mbc is like 200. i thought this was a decent deal.
